CLE-161-01-G-DV
CLE-161-01-G-DV
    SAMTEC(申泰)
    CONN RCPT 122PS .8MM DL GOLD SMD
CLE-161-01-G-DV 数据手册
F-215 CLE–125–01–G–DV CLE–108–01–G–DV CLE–130–01–G–DV (0,80 mm) .0315" CLE SERIES COST EFFECTIVE MICRO SOCKET SPECIFICATIONS Ideal for pass-through applications Mates with: FTE, AW For complete specifications and recommended PCB layouts see www.samtec.com?CLE Insulator Material: Black Liquid Crystal Polymer Contact Material: BeCu Plating: Au over 50µ" (1,27 µm) Ni Current Rating (CLE/FTE): 2.7 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +125°C Contact Resistance: 15 mΩ Insertion Depth: Top Entry = (1,73 mm) .068" to (3,18 mm) .125" with (0,38 mm) .015" wipe, or pass-through Bottom Entry = (3,23 mm) .127" minimum plus board thickness Insertion Force: (Single contact only) 2.0 oz (0,56 N) Normal Force: 75 grams (0,73 N) Withdrawal Force: (Single contact only) 1.2 oz (0,33 N) Max Cycles: 100 with 10µ" (0,25 µm) Au RoHS Compliant: Yes OPTIONS –TR OPTION (0,80 mm) .0315" micro pitch –P OPTION Surface Mount CLE 1 NO. PINS PER ROW PLATING OPTION 01 DV OPTIONS –A Processing: –G 04 thru 90 Lead-Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (04-65) (0,15 mm) .006" max (66-90) = 10µ" (0,25 µm) Gold = Alignment Pin (4 positions minimum) Metal or plastic at Samtec discretion. –K RECOGNITIONS = (3,50 mm) .138" DIA Polyimide film Pick & Place Pad (8 positions minimum) No. of positions x (0,80) .0315 (0,80) .0315 For complete scope of recognitions see www.samtec.com/quality 02 (3,18) .125 (1,20) .047 (0,30) .012 (4,39) .173 x (6,35) .250 –P = Metal Pick & Place Pad (8 positions minimum) (3,51) .138 01 –TR = Tape & Reel Packaging –P OPTION BILITY EL AVAILA TAPE & RE (3,12) .123 (3,30) .130 (4,83) .190 Note: Some lengths, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. arges. No tooling chthe lesser of der is Minimum orantity or 125 pieces. a full reel quantity above minimum. Order any qudesign, manufacture. In-house turn-around. Quick ions for specificat Call Samtecring information. and orde
CLE-161-01-G-DV 价格&库存
很抱歉,暂时无法提供与“CLE-161-01-G-DV”相匹配的价格&库存,您可以联系我们找货
