F-211
CLH–108–F–D–DV–P
CLH–110–F–D–DV
(2,54mm) .100"
CLH–120–F–D–BE
CLH SERIES
SMT LOW PROFILE SOCKET
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?CLH
Insulator Material:
Black Liquid
Crystal Polymer
Contact Material:
Phosphor Bronze
Operating Temp Range:
-65°C to +125°C with Gold
-65°C to +105°C with Tin
Plating:
Au or Sn over
50µ" (1,27µm) Ni
Contact Resistance:
10 mΩ max
Insertion Depth:
(2,67mm) .105" to
(3,43mm) .135"
plug from top, (3,18mm) .125"
min plus board thickness plug
from bottom
Insertion Force:
4.0oz (1,11N) average
Normal Force:
50 grams (0,48N)
Withdrawal Force:
1.1oz (0,31N) average
Max Cycles:
100 with 10µ" (0,25µm) Au
RoHS Compliant:
Yes
1
CLH
NO. PINS
PER ROW
PLATING
OPTION
D
ENTRY
OPTION
OTHER
OPTION
–DV
Mates with:
TSW, MTSW, HW, DW,
EW, ZW, TLW, TSM,
MTLW
–K
= Top
Entry
= (6,50mm) .256"
DIA Polyimide film
Pick & Place Pad
(3 positions min.)
–BE
= Bottom
Entry
–F
–P
= Pick & Place Pad
(3 positions
minimum)
= Pre-plated Gold flash on contact,
75µ" (1,91µm) Matte Tin on tail
–L
= Pre-plated 10µ" (0,25µm)
Gold on contact,
(7,11) .280
x
(5,71) .225
(3,86)
.152
Note: Other Gold plating
options available.
Contact Samtec.
Not always necessary
for auto placement.
Call Samtec.
Processing:
–A
–TR
==Alignment
Pin
Tape & Reel
(4
positions
Packaging
minimum)
(–DV
only)
02 thru 50
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10mm) .004" max
(1,22)
.048
(1,60)
.063
DIA
–LC
= Locking
Clip
No. of Positions x (2,54) .100
(2,54)
.100
02
(1,27)
.050
(5,08)
.200
(2,54)
.100
03
(1,42)
.056
01
TAPE & R
(3,56)
.140
(3,66)
.144
(7,11)
.280
(0,51)
.020
–TR
EEL AVAIL
ABILITY
No to
Minimum oling charges.
a full reel quorder is the lesser of
antity or 12
Order any
5 pieces
qu
In-house deantity above minimum.
sign, manuf
ac
Quick turn
-around. ture.
C
all Samtec
and orderinfor specifications
g informat
ion.
Note: Some lengths,
styles and options are
non-standard, non-returnable.
WWW.SAMTEC.COM
= Tape & Reel
Packaging
(29 positions
maximum)
很抱歉,暂时无法提供与“CLH-107-F-D-BE .”相匹配的价格&库存,您可以联系我们找货
