CLP-148-02-F-D
CLP-148-02-F-D
    SAMTEC(申泰)
    CONN RCPT 96POS 0.05 GOLD SMD
CLP-148-02-F-D 数据手册
F-218 (Rev 14DEC17) CLP–115–02–L–D CLP–107–02–F–D–P 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT CLP–130–02–L–D CLP–116–02–F–DH HIGH MATING CYCLES (1.27 mm) .050" CLP SERIES LOW-PROFILE DUAL WIPE SOCKET High-reliability Tiger Claw™ contacts Mates with: FTSH, FTS, FW SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?CLP Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (CLP/FTSH): 3.4 A per pin (2 pins powered) Voltage Rating: 280 VAC/395 VDC Operating Temp Range: -55 °C to +125 °C Insertion Depth: Top Entry = (1.40 mm) .055" minimum, Bottom Entry = (2.41 mm) .095" minimum plus board thickness DH Entry = (2.31 mm) .091" to (2.67 mm) .105" Normal Force: 60 grams (0.59 N) average Max Cycles: 100 with 10 µ" (0.25 µm) Au RoHS Compliant: Yes (1.27 mm x 1.27 mm) .050" x .050" micro pitch APPLICATIONS CLP Low-profile (2.21 mm) .087" FTSH HORIZONTAL Surface mount Suitable for pass-through applications PASS-THRU CLP NO. PINS PER ROW 1 PLATING OPTION 02 ROW OPTION OTHER OPTION PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (02-35) (0.15 mm) .006" max (36-50)* *(.004" stencil solution may be available; contact IPG@samtec.com) –F = Gold flash on contact, Matte Tin on tail 02 thru 50 = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail For complete scope of recognitions see www.samtec.com/quality –G No. of Positions x (1.27) .050 + (0.43) .017 FILE NO. E111594 100 (1.27) .050 02 01 99 (MOQ Required) = Double Horizontal (Requires FTSH–01 and FTSH–04 lead styles) –A = Alignment Pin (Not available with –PA option) (05, 06, 07, 08, 10, 12, 15, 20, 25, 30, 40 positions only) (–DH option and other sizes. Contact Samtec.) –K = (4.00 mm) .157" DIA Polyimide film Pick & Place Pad (5 positions min.) (6.35) .250 x (3.18) .125 (4.32) .170 (4.57) (3.05) .180 .120 ALSO AVAILABLE = 10 µ" (0.25 µm) Gold (–D only) (0.41) .016 = Bottom Entry (Required for bottom entry applications) –DH –L RECOGNITIONS –BE –D = Double Row (1.27) .050 –P = Pick & Place Pad (5 positions min. –D only) (Not always necessary for auto placement. See Flex Processing.) (2.54) .100 –P OPTION • Single row • Other platings Contact Samtec. (3.43) .135 (2.29) .090 –D –DH A Note: Some sizes, styles and options are non-standard, non-returnable. PIN/ROW A 04-15 (3.56) .140 16-50 (7.11) .280 If odd pins/row, alignment pins are on middle position on centerline of the part. If even pins/row, then alignment pins are between middle two positions. (1.40) .055 –PA (8.25) .325 (3.07) .121 (0.89) .035 DIA (7.00) .275 –PA OPTION = Pick & Place Pad with Alignment Pin (–D only) (Not Available with –A option) Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. –TR = Tape & Reel
CLP-148-02-F-D
物料型号: - CLP-115-02-L-D - CLP-107-02-F-D-P - CLP-130-02-L-D - CLP-116-02-F-DH
器件简介: - 10年制造周期,30微英寸黄金镀层,延长使用寿命 - 高可靠性Tiger Claw™接触点 - 适用于FTSH、FTS、FW系列
引脚分配: - 微间距0.050英寸x 0.050英寸 - 2排引脚,每排2个引脚
参数特性: - 绝缘材料:黑色液晶聚合物 - 接触材料:磷青铜 - 镀层:锡或金,50微英寸(1.27微米)镍上镀 - 电流额定值:每针3.4安培(2针供电) - 电压额定值:280 VAC/395 VDC - 工作温度范围:-55°C至+125°C - 插入深度:顶入至少0.055英寸,底入至少0.095英寸加上板厚 - 正常力:平均60克(0.59牛顿) - 最大周期:100次,10微英寸(0.25微米)金
功能详解: - 适合表面贴装和通孔应用 - 无铅可焊性 - SMT引脚共面性:最大0.004英寸(02-35),最大0.006英寸(36-50)
应用信息: - 低剖面设计 - 适用于水平和通孔处理
封装信息: - 双排选项 - 金闪接触点,尾部镀锡 - 10微英寸(0.25微米)金接触点,尾部镀锡
CLP-148-02-F-D 价格&库存
很抱歉,暂时无法提供与“CLP-148-02-F-D”相匹配的价格&库存,您可以联系我们找货
