DPAF-08-03.0-S-3-2-A-K 数据手册
F-214
DPAM–23–07.0–S–8–2–A
DPAF–23–03.0–S–8–2–A
(2,16 mm) .085"
DPAM, DPAF SERIES
HIGH DENSITY DIFFERENTIAL PAIR ARRAY
DPAM Mates with:
DPAF
DPAF Mates with:
DPAM
PAIRS
PER ROW
DPAM
SPECIFICATIONS
Insulator Material:
Black LCP
Contact Material:
Copper Alloy
Plating:
Au over 50µ" (1,27 µm) Ni
Current Rating (2x3):
2.9 A per pin
Operating Temp Range:
-55°C to +125°C
Contact Resistance:
10.4mΩ
Working Voltage:
300 VAC
Mated Cycles: 100 Cycles
RoHS Compliant: Yes
Lead-Free Solderable: Yes
NO. OF
ROWS
–S
=Eight
Pair
Rows
=30µ" (0,76 µm)
Gold on contact area,
Tin on solder tail
–3
=Three
Pair
Rows
Perimeter
Grounds (TYP)
G1
NO OF
ROWS
–8
–3
02 01 G2 03 04
(MOQ Required)
• Tin-Lead Solder Charge
• Other platings
Contact Samtec.
A
No. of positions x (2,16) .085 + (4,34) .171
(11,89) .468
(6,66)
.262
(0,13)
.005
(1,27)
.050
DIA
(2,16) .085
(1,08) .0425
No. of positions x (2,16) .085 + (2,95) .116
DPAF
PAIRS
PER ROW
– 04, – 06, – 08,
–15, –23
PLATING
OPTION
03.0
–K
=(20,00 mm) 0.80"
DIA Polyimide
film Pick &
Place Pad
–TR
=Tape & Reel
–GP
=Guide Post
(–23 only)
–3
=Three
Pair Rows
Signal
Pairs
(TYP)
NO OF
ROWS
04
02 (2,54)
01 .100
(1,52)
.060
G2
Perimeter Grounds (TYP)
03
(0,13)
.005
(6,45)
.254
(2,16) .085
Solder crimped on tail
(1,08) .0425
A
OPTION
= Lead-Free Tin Alloy
96.5% Sn/ 3%Ag/
.5% Cu
Solder Crimp
=(20,00 mm)
0.80" DIA
Polyimide
film
Pick &
Place Pad
(1,27)
.050
DIA
WWW.SAMTEC.COM
–8
–3
–K
–2
=Eight
Pair Rows
=30µ" (0,76 µm)
Tin on solder tail
A
(1,27)
.050
SOLDER
TYPE
–8
G1
(1,27) .050
DPAM/DPAF
Rated @ 3dB Insertion Loss*
10 mm Stack Height
Single-Ended Signaling
8 GHz / 16 Gbps
Differential Pair Signaling
7 GHz / 14 Gbps
*Performance data includes effects of a non-optimized PCB.
Complete test data available at www.samtec.com?DPAM,
www.samtec.com?DPAF or contact sig@samtec.com
NO. OF
ROWS
–S
Note: Patented
Note: Some sizes, styles and
options are non-standard,
non-returnable.
–2
= Lead-Free
Tin Alloy
96.5% Sn/
3% Ag/.5% Cu
Solder Crimp
(2,54)
.100
Signal Pairs (TYP)
(24,59) .968
(1,27)
.050
notes at
Download app ppnote
/a
om
c.c
te
m
www.sa
@ samtec.com
Contact SIG
on protocols
for questions
ALSO AVAILABLE
OPTION
A
RECOGNITIONS
el
Fibre Chann
Rapid I/O ®
PCI Express
SATA ™
InfiniBand
XAUI
t I/O)
MGT (Rocke
A
(2,54)
.100
For complete scope of
recognitions see
www.samtec.com/quality
s
ocol
t
o
r
P
rted
o
p
p
Su
SOLDER
TYPE
–8
– 04, –06
– 08, –15, –23
For complete specifications and
recommended PCB layouts see
www.samtec.com?DPAM or
www.samtec.com?DPAF
PLATING
OPTION
07.0
A
(23,32)
.918
(10,62)
.418
DPAF
DPAM MATED
LEAD HEIGHT*
STYLE
–03.0
10 mm
–07.0
*Processing
conditions will
affect mated height.
SIZE
–04 x –3
–06 x –3
–04 x –8
–06 x –8
–08 x –8
–15 x –8
–23 x –8
–08 x –3
–15 x –3
–23 x –3
USABLE PAIRS
PER ARRAY*
6 Pairs
12 Pairs
16 Pairs
32 Pairs
48 Pairs
104 Pairs
168 Pairs
18 Pairs
39 Pairs
63 Pairs
*Assumes first and last pair in
each row are grounded
–TR
=Tape
& Reel
