ERM5-030-05.0-S-DV-TR 数据手册
RUGGED HIGH-SPEED STRIPS
FEATURES & BENEFITS
Edge Rate® rugged high-speed connector strips are designed for high-speed, high cycle applications,
and enabled by Samtec's signal integrity-optimized Edge Rate® contact system.
• Up to 1.5 mm contact wipe for a reliable connection
• 20 to 200 positions
• Choice of 0.50 mm, 0.635 mm or 0.80 mm pitch
• 0.50 mm pitch system offers up to 40% PCB space savings vs. 0.80 mm pitch
• 0.635 mm pitch system with extremely slim 2.5 mm body width
• Rugged latching, extended guide posts and 360° shielding
Signal integrity-optimized
Edge Rate® contact
system reduces
broadside coupling
• Severe Environment Testing qualified (ERM8/ERF8); aligns with MIL-DTL-55302.
Visit samtec.com/set
EDGE RATE® STACK HEIGHT FLEXIBILITY
(shown in mm)
5
7
8
ERM6/
ERF6
10
9
12
11
ERM5/ERF5
13
14
15
16
18
17
ERM8/ERF8
Rugged 360º shielding
reduces EMI
KEY SPECIFICATIONS
SERIES
PITCH
ERM5 / ERF5
0.50 mm
ERM6 / ERF6
0.635 mm
ERM8 / ERF8
0.80 mm
F-224 (Rev 13FEB24)
INSULATOR
MATERIAL
TERMINAL MATERIAL
Phosphor Bronze or BeCu (ERM5),
BeCu (ERF5)
Black LCP
Copper Alloy
Phosphor Bronze or BeCu (ERM8),
BeCu (ERF8)
PLATING
Au or Sn
over 50 µ"
(1.27 µm)
Ni
OPERATING
TEMP RANGE
-55 °C to +125 °C
CURRENT
RATING
VOLTAGE
RATING
1.5 A
190 VAC
1.4 A
155 VAC
1.4 A
225 VAC
LEAD-FREE
SOLDERABLE
Yes
samtec.com/EdgeRate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(0.50 mm) .0197" PITCH • RUGGED HIGH-SPEED STRIPS
SERIES
POSITIONS
PER ROW
–010, –020,
–030, –040,
–050, –060,
–070, –075
ERM5
= Header
ERF5
= Socket
LEAD
STYLE
PLATING
OPTION
–02.0
- DV -
–L
= 2 mm Body Height
(ERM5 only)
(Not available
with –K–TR)
(Not required. Only
specify one option
in callout. Will
only mate with a
corresponding option)
= 10 µ"
(0.25 µm)
Gold on
contact,
Matte Tin
on Tail
–04.0
= 4 mm Body Height
(ERM5 only)
OPTIONS
–K
–WT
–L
–07.0
= Latching
(Available with
–02.0 and –05.0
Lead Styles only)
–P
= Plastic Pick
& Place Pad
1RRI3RVLWLRQV[
ERM5
Board Mates:
ERF5
LEAD
A
B
STYLE (ERM5) (ERF5)
(1.00 mm)
.039"
Nominal
Wipe
ERF5
Board Mates:
ERM5
Right-Angle
Socket
ERF5-RA
Board Mates:
ERM5
Note:
Some lengths,
styles and
options are
non-standard,
non-returnable.
POSITIONS
PER ROW
–010, –020, –030,
–040, –050
01
PLATING
OPTION
D
(4.84)
.191
N/A
–04.0
(6.84)
.269
N/A
–05.0
(7.84)
.309
(4.91)
.193
-07.0
N/A
(6.91)
.272
RA
ERF5
LEAD STYLE
ERM5
LEAD
STYLE
-05.0
-07.0
-02.0
(7.00)
.276
(9.00)
.354
-04.0
(9.00)
.354
(11.00)
.433
-05.0
(10.00)
.394
(12.00)
.472
*Processing conditions will
affect mated height.
View complete specifications at: samtec.com?ERM5 or samtec.com?ERF5
–02.0
MATED HEIGHT*
1RRI3RVLWLRQV[
ERF5
–FR
= Full Reel
Tape & Reel
(must order
maximum quantity
per reel; contact
Samtec for
quantity breaks)
= (6.00 mm) .236"
DIA Polyimide
Film Pick &
Place Pad
(ERF5 only)
= Weld Tab
= 7 mm Body Height
(ERF5 only &
Available up to
50 positions only)
–TR
= Tape & Reel
= (3.50 mm) .138"
DIA Polyimide
Film Pick &
Place Pad
(ERM5 only)
–FL
–05.0
"X"R
(Required
in callout)
= Friction Lock
(max. –030 positions)
= 5 mm Body Height
PICK &
PLACE PAD
"X"R
–L
–TR
= 10 µ" (0.25 µm) Gold on
contact, Matte Tin on tail
= Tape & Reel
–FR
= Full Reel Tape & Reel
(must order maximum quantity per reel;
contact Samtec for quantity breaks)
No. of Positions x
(0.50) .0197 + (10.30) .406
(6.83)
.269
(4.75)
.187
View complete specifications at: samtec.com?ERF5-RA
samtec.com/EdgeRate
F-224 (Rev 13FEB24)
ERM5-030-05.0-S-DV-TR 价格&库存
很抱歉,暂时无法提供与“ERM5-030-05.0-S-DV-TR”相匹配的价格&库存,您可以联系我们找货
