ET60T-000-3-08-D02-L-R1-S
    SAMTEC(申泰)
    板对板连接器
ET60T-000-3-08-D02-L-R1-S 数据手册
ET60T–D04–5–03–A04–L–R1–S F-217 (Rev 13FEB17) ET60T–D04–3–08–A04–S–R1–S (5.50 mm) .217"(PWR) (2.54 mm) .100"(SIG) ET60T SERIES RIGHT-ANGLE POWER/SIGNAL HEADER Mates with: ET60S POWER POSITIONS (LEFT) ET60T ROWS SIGNAL POSITIONS –0 –02, –04, –06, –08, –10, –12 SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?ET60T –AXX* = No Signal = AC Power Positions (–02, –03, –04, –05, –06) Insulator Material: Black LCP Terminal Material: Signal: Phosphor Bronze Power: Copper Alloy Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: Power: 60 A max per blade (2 pins powered @ 95 °C; 30 °C temperature rise) Signal: 2.8 A max (6 pins powered @ 95 °C; 30 °C temperature rise) Operating Temp Range: -40 °C to +105 °C Voltage Rating: 250 V max RoHS Compliant: Yes = 3 Rows –3 –DXX –5* = DC Power Positions (–02, –03, –04, –05, –06, 07, 08, 09, 10) = 5 Rows = 5 Rows –00 –SXX* = No Signal = Split Power –000 Note: –AXX*, –SXX*, –5* & –T* are Preliminary = No Power B (2.54) .100 A C (10.00) .394 PROCESSING A + B + C + (26.98) 1.062 (2.84) .112 Lead-Free Solderable: Yes For complete scope of recognitions see www.samtec.com/quality (0.64) .025 SQ A + B + C + (33.98) 1.338 (7.50) .295 (1.27) .050 (5.50) .217 RECOGNITIONS (10.00) .394 (2.50) .098 (29.25) 1.152 (9.40) .370 FILE NO. E111594 (5.00) .197 ALSO AVAILABLE (5.17) .204 (3.00) .118 (MOQ Required) • Increased creepage and clearance with the removal of contacts • Hot swapable Contact Samtec. –01, –02, –03, –04, –05, –06, –07, –08 = 3 Rows (4.81) .189 (3.00) .118 ET60T–D03–3–08–A03–X–R1–S (2.00) .079 A (5.50) .217 (24.90 .980 (3.33) .1131 DIA D C (10.00) .394 A + D + C + (27.21) 1.071 (0.64) .025 SQ A + D + C + (34.21 ) 1.347 (5.50) .217 (1.27) .050 Notes: Some lengths, styles and options are non-standard, non-returnable. EXTreme Ten60Power™ is a trademark of Molex Incorporated and is dual sourced by Molex® (24.45) .963 (5.50) .217 (5.64) .222 (4.57) .180 ET60T–D04–5–03–A04–X–R1–S Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. ET60T–D04–3–08–A04–L–R1–T F-217 (Rev 13FEB17) (5.50 mm) .217"(PWR) (2.54 mm) .100"(SIG) ET60T SERIES ET60T–D04–3–08–A00–T–R1–S RIGHT-ANGLE POWER/SIGNAL HEADER POWER POSITIONS (RIGHT) –AXX* = AC Power Positions (–02, –03, –04, –05, –06) –DXX = DC Power Positions (–02, –03, –04, –05, –06, 07, 08, 09, 10) –SXX* PLATING GUIDE POST TAIL –R1 –L = Right-angle Through-hole (Use with (1.60 mm) .062" thick card) = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (Not available for 5 rows) –S = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail OPTION –S –H = Side Guide Post = Hot Swap (Leave blank for no Hot Swap –T* = Top Guide Post = Split Power –000 Note: –AXX*, –SXX*, –5* & –T* are Preliminary = No Power A POWER POWER POSITIONS POSITIONS DC (LEFT) (RIGHT) POWER –02 –02 –03 –03 –04 –04 –05 –05 –06 –06 –07 –07 –08 –08 –09 –09 –10 –10 C AC POWER A + D + C + (11.47) .452 (5.50) **(7.50) .217 .295 (11.00) **(15.00) .433 .591 (16.50) **(22.50) .650 .886 **(22.00) **(30.00) .866 1.181 **(27.50) **(37.50) 1.083 1.476 **(33.00) N/A 1.299 **(38.50) N/A 1.516 **(44.00) N/A 1.732 (49.50) N/A 1.949 (2.00) .079 D (14.98) .590 A C A + D + C + (19.71) .776 (0.64) .025 SQ ET60T–D04–5–03–A04–X–R1–T C A **Not Released SIGNAL POSITIONS PER ROW (3 Row) B *–02 (2.54) .100 *–04 (7.62) .300 *–06 (12.70) .500 (17.78) .700 (22.86) .900 (27.94) 1.100 –08 *–10 *–12 *Not Tooled **Not Released SIGNAL POSITIONS PER ROW (5 Row) D **–01 N/A **–02 (2.00) .079 (4.00) .157 (6.00) .236 (8.00) .315 (10.00) .394 (12.00) .472 (14.00) .551 **–03 *–04 **–05 **–06 **–07 **–08 A + C + (21.50) .846 A + C + (28.50) 1.122 (1.27) .050 (5.50) .217 (3.33) .1131 DIA (5.50) .217 (4.50) .177 (5.50) .217 ET60T–D04–0–00–A04–X–R1–S Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. (29.25) 1.152
ET60T-000-3-08-D02-L-R1-S 价格&库存
很抱歉,暂时无法提供与“ET60T-000-3-08-D02-L-R1-S”相匹配的价格&库存,您可以联系我们找货
