FCF8-30-01-L-03.00-S-1
    SAMTEC(申泰)
    FCF8 CABLE ASSEMBLY
FCF8-30-01-L-03.00-S-1 数据手册
HIGH-SPEED COST EFFECTIVE COAX CABLE (0.80 mm) .0315" PITCH • FCF8/FCS8 SERIES FCF8 FCF8 Mates: FCS8 - Notes: Design your full cable assembly with Samtec’s High-Speed Cable Solutionator® at www.samtec.com/cablebuilder - - 01 –10, –20, –30 SPECIFICATIONS Cable: 38 AWG coax Overmold: Nylon Terminal Material: Phosphor Bronze Contact Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -25 °C to +105 °C Current Rating: 1.8 A per pin (1 pin powered) NO. OF POSITIONS PLATING OPTION - –L –“XX.XX” = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = Length in Inches 03.00" (76.2 mm) minimum GND GND A B N 01 GND GND A B –10 (11.85) (19.00) .467 .748 –20 (19.85) (27.00) .781 1.063 –30 (27.85) (35.00) 1.096 1.378 (12.55) .494 ALSO AVAILABLE (2.42) .095 FCS8 - NO. OF POSITIONS –10, –20, –30 SPECIFICATIONS Insulator Material: Black LCP Contact Material: BeCu Contact Plating: Au or Sn over 50 µ" (1.27 µm) Ni Shield: Nickel Plated Phosphor Bronze Operating Temp Range: -55 °C to +125 °C Current Rating: 1.8 A per pin (1 pin powered) NO. OF POSITIONS 01 N Some lengths, styles and options are non-standard, non-returnable. Mates: FCF8 S CABLE LENGTH + (16.43) .647 Cable lengths longer than 40.00" (1 meter) are not supported with S.I. test data. FCS8 - CABLE LENGTH A (7.46) .294 - 01 - - PLATING OPTION - S Other sizes and lengths (MOQ Required) A - –L “X”R –TR = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) NO. OF POSITIONS A B C D –10 (16.59) .653 (15.56) .613 (10.70) .421 (13.06) .514 –20 (24.59) .968 (23.56) .928 (18.70) .736 (21.06) .829 –30 (32.59) 1.283 (31.56) 1.243 (26.70) 1.051 (29.06) 1.144 PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.15 mm) .006" max* *(.004" stencil solution may be available; contact ipg@samtec.com) Note: Some sizes, styles and options are non-standard, non-returnable. B (7.48) .294 C D samtec.com?FCF8 or samtec.com?FCS8 F-224 WEB Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FCF8-30-01-L-03.00-S-1 价格&库存
很抱歉,暂时无法提供与“FCF8-30-01-L-03.00-S-1”相匹配的价格&库存,您可以联系我们找货
