FCS8-10-01-L-S-A-TR
FCS8-10-01-L-S-A-TR
    SAMTEC(申泰)
    SMD,P=0.8mm,卧贴
    TCS8 插座组件
FCS8-10-01-L-S-A-TR 数据手册
F-217 FCF8–20–01–L–03.00–S FCF8–10–01–L–03.00–S FCS8–10–01–L–S–A–TR FCS8–20–01–L–S–A–TR (0.80 mm) .0315" FCF8, FCS8 SERIES HIGH-SPEED COST EFFECTIVE COAX CABLE SPECIFICATIONS For complete specifications see www.samtec.com?FCF8 Cable: 38 AWG coax Overmold: Nylon Terminal Material: Phosphor Bronze Contact Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -25 °C to +105 °C Current Rating: 1.8 A per pin (1 pin powered per row) RoHS Compliant: Yes RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality FILE NO. E111594 Notes: Design your High-Speed Cable with Samtec’s High-Speed Cable Solutionator® at www.samtec.com/hdr NO. OF POSITIONS FCF8 Mates with: FCS8 CABLE LENGTH PLATING OPTION 01 –L –10, –20, –30 –“XX.XX” = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = Length in Inches 03.00" (76.2 mm) minimum CABLE LENGTH + (16.43) .647 NO. OF POSITIONS GND GND A Insulator Material: Black LCP Contact Material: BeCu Contact Plating: Au or Sn over 50 µ" (1.27 µm) Ni Shield: Nickel Plated Phosphor Bronze Operating Temp Range: -55 °C to +125 °C Current Rating: 1.8 A per pin (1 pin powered per row) RoHS Compliant: Yes PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.15 mm) .006" max –10 –20 (19.85) (27.00) .781 1.063 –30 (27.85) (35.00) 1.096 1.378 GND ALSO AVAILABLE (MOV Required) (12.55) .494 • Other sizes and lengths Contact Samtec. (2.42) .095 NO. OF POSITIONS FCS8 Mates with: FCF8 (0.80) .0315 PLATING OPTION 01 –L –10, –20, –30 A (7.46) .294 (0.30) .012 S = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail A TR –TR = Tape & Reel NO. OF A B C D POSITIONS (16.59) .653 (15.56) .613 (10.70) .421 (13.06) .514 –10 (24.59) .968 (23.56) .928 (18.70) .736 (21.06) .829 –20 (32.59) 1.283 (31.56) 1.243 (26.70) 1.051 (29.06) 1.144 –30 (7.48) .294 B • Weld tabs • Positive latching RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality B N 01 GND Some lengths, styles and options are non-standard, non-returnable. SPECIFICATIONS B A (11.85) (19.00) .467 .748 01 N Cable lengths longer than 40.00" (1 meter) are not supported with S.I. test data. For complete specifications and recommended PCB layouts see www.samtec.com?FCS8 S • Shielded for EMI protection C D (0.49) .019 (1.85) .073 (0.20) .008 (1.32) .052 DIA FILE NO. E111594 Note: Some lengths, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
FCS8-10-01-L-S-A-TR 价格&库存
很抱歉,暂时无法提供与“FCS8-10-01-L-S-A-TR”相匹配的价格&库存,您可以联系我们找货
FCS8-10-01-L-S-A-TR
  • 1+38.64240
  • 10+33.57720
  • 30+30.56400
库存:3
FCS8-10-01-L-S-A-TR
  • 1+42.054381+5.46508
  • 10+35.7627410+4.64746
  • 25+33.5164325+4.35555
  • 50+31.9140050+4.14731
  • 100+30.39108100+3.94940
  • 250+28.48769250+3.70205
库存:1292
FCS8-10-01-L-S-A-TR
  • 500+23.86117500+3.10082
  • 1000+22.363901000+2.90625
库存:1292
