FLE-136-01-G-DV-K-TR
    SAMTEC(申泰)
    .050 MICRO STRIPS
FLE-136-01-G-DV-K-TR 数据手册
F-215 FLE–110–01–G–DV FLE–120–01–G–DV FLE–150–01–G–DV (1,27 mm) .050" FLE SERIES COST EFFECTIVE RELIABLE SOCKET SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?FLE Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au over 50µ" (1,27 µm) Ni Current Rating: 2 A per pin (6 adjacent pins powered) Operating Temp Range: -55°C to +125°C Contact Resistance: 15mΩ Insertion Depth: (1,83 mm) .072" to (4,37 mm) .172" or pass-through Insertion Force: (Single contact only) 1.5 oz (0,42 N) Normal Force: 100 grams (0,98 N) Withdrawal Force: (Single contact only) 1.5 oz (0,42 N) Max Cycles: 100+ RoHS Compliant: Yes Ideal for pass-through applications Tiger Beam™ contact Mates with: FTSH, FTS, FW, FFMD, FMTP Surface Mount Available with optional Pick & Place pads (1,27 mm) .050" micro pitch FLE 1 NO. PINS PER ROW PLATING OPTION 01 DV OPTIONS Processing: –A Lead-Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max –G 02 thru 50 = 10µ" (0,25 µm) Gold = Alignment Pin (Metal or plastic at Samtec discretion) (3 positions minimum) RECOGNITIONS –K For complete scope of recognitions see www.samtec.com/quality = (4,25 mm) .167" DIA Polyimide film Pick & Place Pad (5 positions minimum) (6,35) .250 x (4,17) .164 FILE NO: 090871_0_000 No. of Positions x (1,27) .050 + (0,11) .0045 (1,27) .050 (1,27) .050 –TR (4,74) .187 (3,33) .131 = Tape & Reel –P OPTION (0,51) .020 BILITY EL AVAILA ALSO AVAILABLE TAPE & RE (MOQ Required) • Other platings Contact Samtec. –P = Metal Pick & Place Pad (5 positions minimum) (4,55) (4,36) .179 .172 (4,60) .181 arges. No tooling chthe lesser of der is or um im pieces. in M antity or 125 a full reel quantity above minimum. Order any qudesign, manufacture. In-house turn-around. Quick ions for specificat Call Samtecring information. and orde Note: Some lengths, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
FLE-136-01-G-DV-K-TR 价格&库存
很抱歉,暂时无法提供与“FLE-136-01-G-DV-K-TR”相匹配的价格&库存,您可以联系我们找货
