SMT MICRO
HEADER & SOCKET
(1.27 mm) .050" PITCH • FTR/RSM SERIES
FTR
Mates:
RSM, SMS, SLM
FTR
-1
RSM
NO. PINS
PER ROW
LEAD
STYLE
02 thru 40
Mates:
FTR, HTMS, HDWM,
DWM, TML, ZML, TMS
–L
Specify
LEAD
STYLE
from
chart
PROCESSING
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
RSM: (0.10 mm) .004" max
FTR: (0.10 mm) .004" max (02-20)
FTR: (0.15 mm) .006" max (21-40)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
LEAD
STYLE
A
–01
(5.84) .230
–02
(2.54) .100
–03
(3.18) .125
–51
(4.83) .190
–52
(5.21) .205
–53
(7.24) .285
–54
(8.51) .335
–55
(9.91) .390
–56
(10.29) .405
–57
(10.92) .430
NO. PINS
PER ROW
—D
02
02 thru 36
–P
= Plastic Pick & Place Pad
(5 positions min. for –D)
(8 positions min. for –S)
–TR
= Tape & Reel
(4 positions min. for –S)
—LC
—A
PLATING
OPTION
–L
ROW
OPTION
–S
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
[1R
RI3RVLWLRQV
–LC
= Locking Clip
(6 positions min. for –D)
(Not available with -A)
(Manual placement required)
= Full Reel Tape & Reel
(must order max. quantity
per reel; contact Samtec
for quantity breaks)
-1
–A
= Alignment Pin
(Metal or plastic
at Samtec discretion)
(Not available with -LC)
–FR
RSM
–“XX”
= Polarized
–D
= 10 µ" (0.25 µm)
Gold on post,
Gold flash on tail
—S
OPTION
= Double Row
= Single Row
–D
= Double Row
OPTION
–K
= (6.25 mm) .246" DIA
Polyimide film
Pick & Place Pad
(5 positions
minimum for –D)
(7 positions
minimum for –S)
–P
ALSO AVAILABLE
MOQ Required
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
= Single Row
–G
1RRI3RVLWLRQV
ROW
OPTION
–S
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
RSM: Phosphor Bronze
Terminal Material:
FTR: Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
FTR: -55 °C to +105 °C with Tin;
FTR: -55 °C to +125 °C with Gold
RSM: -55 °C to +125 °C
Current Rating (FTR/RSM):
3.8 A per pin
(2 pins powered)
Voltage Rating:
290 VAC
Lead Size Accepted:
RSM: (0.46 mm) .018" SQ
Insertion Depth:
RSM: Top Entry =
(2.64 mm) .104"to (5.84 mm) .230"
with (0.38 mm) .015" wipe, or
pass-through.
RSM: Bottom Entry =
(5.49 mm) .216" minimum
(Add board thickness for
correct post OAL)
PLATING
OPTION
Other platings
Locking clips
—S
—D
= Plastic Pick &
Place Pad
(5 positions
minimum for –D)
(6 positions
minimum for –S)
–TR
= Tape & Reel
–FR
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
samtec.com?FTR or samtec.com?RSM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
很抱歉,暂时无法提供与“FTR-134-03-S-S”相匹配的价格&库存,您可以联系我们找货
