FTSH-108-01-L-D-RA-K 数据手册
F-219 (Rev 11MAY20)
FTSH–150–02–L–D
FTSH–115–03–L–D–RA
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
FTSH–125–01–F–D
(1.27 mm) .050"
FTSH SERIES
THROUGH-HOLE MICRO HEADER
Impedance matched
for high-speed
applications
(Mated with
CLP Series)
Board Mates:
CLP, FLE
SPECIFICATIONS
For complete specifications
see www.samtec.com?FTSH
Cable Mates:
FFSD, FFTP
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating (FTSH/CLP):
3.4 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
RoHS Compliant:
Yes
(1.27 mm)
.050"
micro pitch
(2.51 mm)
.099"
Mates with
socket strips
or IDC cable
Optional end
shrouds and
ejector shrouds
PROCESSING
HIGH-SPEED CHANNEL PERFORMANCE
Lead-Free Solderable:
Yes
Rating based on Samtec reference
channel. For full SI performance data
visit Samtec.com or contact
SIG@samtec.com
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
1
FTSH
8
Through-hole,
right-angle or
surface mount
G b p s
NO. PINS
PER ROW
LEAD
STYLE
PLATING
OPTION
D
TAIL
OPTION
OPTION
OTHER
OPTIONS
FILE NO. E111594
LOCKING CLIP
FFSD
For single
STRIP ASSEMBLY
LOCKING
mating
CLIP
cycle
with the
PC
ġ
FFSD. BOARD
Specify
-LC after tail option.
Lead Style -01 and
10 pins/row minimum.
5-9 pins/row not available
in combination with keying
shroud (-K).
Specify
LEAD
STYLE
from
chart
02 thru 50
02
(1.27)
.050
01
02
ALSO AVAILABLE
(0.40)
.016
SQ
99
(3.43)
.135
A
(2.51)
.099
–01
Notes:
See SFM/TFM for positive
alignment feature.
–02
Some sizes, styles and
options are non-standard,
non-returnable.
–04
–03
A
MATES OPTION
WITH
(3.05) FFSD
.120
(1.91) FLE
.075
(1.65) CLP-D
.065
(3.81)
N/A
.150
–ES
–EJ
–EP
–EL
Z
(1.55)
.061
(15.77)
.621
(5.87)
.231
(6.53)
.257
= End Shroud
with Board Lock
(Style –02 & –03)
9 pins/row min.
= Ejector Shroud
(Style –01 only)
10 pins/row min.
25 pins/row max.
–RA not available
–EP
(11.18)
.440
–RA
–K
(1.27)
.050
–EJ
(3.20)
.126
(2.29)
.090
–K
(2.29)
.090
–ES
–RA –ES
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
–EP
= End Shroud
with Guide Post
(Style –02 & –03)
9 pins/row min.
–EL
(1.91)
.075
DIA
–EL
(2.16) .085
(5.08)
.200
–ES
= End Shroud
(Style –02 & –03)
9 pins/row min.
–EJ
(2.29)
.090
(1.27)
.050
(1.27) .050
LEAD
STYLE
= Rightangle
100
(MOQ Required)
• Molded Pick & Place pads
• Other platings
–RA
–“XXX”
(3.05)
.120
(2.29)
.090
(3.43)
.135
01
Leave
blank for
straight tail
(1.17) .046
99
No. of positions x (1.27) .050
= Polarized Position
(Specify position
of omitted pin)
(Not available
with -EX options)
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
100
–EX OPTION SHOWN
–L
= Gold flash on post,
Matte Tin on tail
No. of positions x (1.27) .050 + Z
(4.78)
.188
–F
Leave blank for
RIght-angle
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
(1.27)
.050
= Keying Shroud
for mating
with FFSD
(Style –01 only,
05, 08, 10, 13, 15,
17, 20 & 25
pins/row only
and 13, 17, 20
& 25 only
with –EJ option)
FTSH-108-01-L-D-RA-K 价格&库存
很抱歉,暂时无法提供与“FTSH-108-01-L-D-RA-K”相匹配的价格&库存,您可以联系我们找货
