HDAM-23-12.0-S-13-2-P
    SAMTEC(申泰)
    2.00 MM X 1.20 MM HD MEZZ RUGGED
HDAM-23-12.0-S-13-2-P 数据手册
HDAM–23–17.0–S–13–2 F-224 SUPPLEMENT HDAM–11–12.0–S–13–2 (2.00 mm) .0787" HDAM SERIES RUGGED ELEVATED HIGH-DENSITY ARRAY SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?HDAM Mates with: HDAF Open-pin-field for Single-Ended or Differential Pair configurations Intermateable with Molex HD Mezz Insulator Material: Black LCP Contact Material: Copper Alloy Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 3.4 A per pin (6 adjacent pins powered) Operating Temp Range: -55 °C to +125 °C Working Voltage: 200 VAC Mated Cycles: 100 RoHS Compliant: Yes Lead-Free Solderable: Yes Lead-Free Solder Charge 299, 195 and 143 pins Elevated stack heights of 20 mm, 25 mm, 30 mm and 35 mm RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality HDAM NO. PINS PER ROW LEAD STYLE PLATING OPTION Specify LEAD STYLE from chart = 30 µ" (0.76 µm) Gold on contact area, Matte Tin on tails and guide pins FILE NO. E111594 DIFFERENTIAL APPLICATIONS —11, —15, —23 (1.20) .0472 13 —S SOLDER TYPE —2 = Lead-Free Tin Alloy 95.5% Sn/ 3.8% Ag/0.7% Cu Solder Charge OPTION —P = Pick & Place Pad ARRAY 11x13 15x13 23x13 (22.50) .886 44 60 92 1A ALSO AVAILABLE (MOQ Required) • Tin-Lead Solder Charge • Other platings Notes: HD Mezz is a trademark of Molex Incorporated —TR —FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (5.09) .200 1M *2:1 S:G Ratio (2.00) .0787 Leave blank for tray packaging =Tape & Reel (2.00) .0787 PAIR COUNT* PACKAGING No. of Pins Per Row x (2.00) .0787 + (16.06) .632 LEAD STYLE No. of Pins Per Row x (2.00) .0787 + (11.55) .455 (1.20) .0472 —12.0 —17.0 A (14.41) .567 (19.41) .764 A Some lengths, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
HDAM-23-12.0-S-13-2-P 价格&库存
很抱歉,暂时无法提供与“HDAM-23-12.0-S-13-2-P”相匹配的价格&库存,您可以联系我们找货
