HMTSW-120-08-SM-D-285
    SAMTEC(申泰)
    MODIFIED .025 SQUARE POST TERMIN
HMTSW-120-08-SM-D-285 数据手册
MODIFIED .025" SQ POST HEADERS (2.54 mm) .100" PITCH • MTSW/HMTSW SERIES MTSW/HMTSW SERIES Board Mates: SSW, SSQ, ESW, ESQ, BCS, BSW CES, SLW, HLE, SSM Cable Mates: IDSD, IDSS - MTSW HMTSW 02 thru 25 = (5.08 mm) .200" Pitch (Every other position filled) = .200" (5.08 mm) Center Version LEAD STYLE PROCESSING Lead–Free Solderable: MTSW: No, Lead Wave Only HMTSW: Yes (2.54) .100 x No. of Positions A (2.54) .100 (2.48) .098 C LEAD STYLE Specify LEAD STYLE from chart = .100" (2.54 mm) Center Version –2 = Hi-Temp Modified Strip - 01 thru 50 = (2.54 mm) .100" Pitch (All positions filled) Insulator Material: MTSW: Black Glass Filled Polyester HMTSW: Natural Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin —S NO. PINS PER ROW –1 = Modified Strip SPECIFICATIONS - PIN CENTERS A – 06 (7.62) .300 – 07 (10.92) .430 – 08 (13.46) .530 – 09 (18.54) .730 – 10 (21.08) .830 – 11 (23.62) .930 – 12 (26.16) 1.030 – 13 (31.24) 1.230 – 21 (36.32) 1.430 – 22 (16.00) .630 – 23 (11.30) .445 – 24 (12.19) .480 – 27 (33.78) 1.330 – 28 (28.70) 1.130 B A —D (5.08) .200 FOR ”B” = (2.29) .090 (5.02) .198 C B A —T (7.62) .300 (7.56) .298 C B A —Q (7.62) .300 (7.56) .298 Straight Pin Versions MTSW HMTSW C B Straight Pin Versions C LEAD STYLE MAXIMUM STRAIGHT – 06 (2.79) .110 – 07 (6.10) .240 – 08 (8.64) .340 – 09 (13.72) .540 – 10 (16.26) .640 – 11 (18.80) .740 – 12 (21.34) .840 – 13 (26.42) 1.040 – 21 (31.50) 1.240 – 22 (11.18) .440 – 23 (6.48) .255 – 24 (7.37) .290 – 27 (28.96) 1.140 – 28 (23.88) .940 Note: These Series are non-standard, non-returnable. F-221 samtec.com?MTSW or samtec.com?HMTSW Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. - - PLATING OPTION - –F ROW OPTION - –S = Gold flash on post, Matte Tin on tail = Single Row –L = Double Row - “XXXX” –LL –Q –LA = Double Row .200" (5.08 mm) row space –T = Polarized (Specify ‘XXX’ as position number) = Locking Lead (not available with –RE, not available in single row 1 or 2 positions) (Available on tails from (2.29 mm) .090" to (10.16 mm) .400" only) –T –G POLARIZED OPTION “XXX” = Right-angle = Triple Row = 10 µ" (0.25 µm) Gold on post, Gold flash on balance - OTHER OPTION –RA or –RE = “C” Dimension (Specify post height in INCHES .005" (0.13 mm) increments) –D = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail POST HEIGHT = –RA option with –LL Option (Maximum “C” = (13.46 mm) .530") = Matte Tin C (2.54) .100 x No. of Positions —S (3.02) .119 D (3.09) .122 E C —D –RX OPTION D –RA (1.52) .060 – RE (4.06) .160 (6.10) .240 (5.56) .219 E FOR ”E” = (2.29) .090 MIN FOR –RA & –RE) C —T (8.12) .320 (8.10) .319 E C —Q (8.12) .320 (8.10) .319 MTSW HMTSW Right-Angle Versions (-RA Options) Right-Angle Versions (-RE Options) Single Row Only (HMTSW –S &–D = 36 positions maximum) E C C LEAD STYLE MAXIMUM with/–RA – 06 Not Available Not Available – 07 (3.30) .130 Not Available MAXIMUM with/–RE – 08 (5.84 .230 (3.30) .130 – 09 (10.92 .430 (8.38) .330 – 10 (13.46) .530 (10.92) .430 – 11 (16.00 .630 (13.46) .530 (16.00) .630 – 12 (18.54) .730 *– 13 (23.62) .930 (21.08) .830 *– 21 (28.70) 1.130 (26.16) 1.030 (5.84) .230 – 22 (8.38) .330 *– 23 (3.68) .145 *– 24 (4.57) .180 *– 27 (26.16) 1.030 (23.62) .930 *– 28 (21.08) .830 (18.54) .730 Not Available * Styles –21, –23, –24, –27 not available with –D Right-angle Styles –13, –21, –23, –24, –27, –28 not available with –T or –Q Right-angle samtec.com?MTSW or samtec.com?HMTSW Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221
HMTSW-120-08-SM-D-285 价格&库存
很抱歉,暂时无法提供与“HMTSW-120-08-SM-D-285”相匹配的价格&库存,您可以联系我们找货
