HTMS-112-56-G-S
HTMS-112-56-G-S
    SAMTEC(申泰)
    CONN HDR .050" 11POS
HTMS-112-56-G-S 数据手册
THROUGH-HOLE MICRO HEADER (1.27 mm) .050" PITCH • TMS/HTMS SERIES TMS/HTMS Mates: SMS, SLM, RSM SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (TMS/SMS): 5 A per pin (2 pins powered) Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold SERIES - NO. PINS PER ROW 1 TMS - 01 thru 50 = Standard HTMS = High Temp LEAD STYLE - - PLATING OPTION ROW OPTION –L Specify LEAD STYLE from chart (1.27) .050 x No. of Positions (4.98) .196 (2.54) .100 Note: Some lengths, styles and options are non-standard, non-returnable. F-224 –“XXX” = Polarized Position (Specify position of omitted pin) A B –01 (11.43) .450 (5.84) .230 –02 (8.13) .320 (2.54) .100 –21 (12.83) .505 (5.84) .230 –51 (10.41) .410 (4.83) .190 –52 (10.80) .425 (5.21) .205 –53 (12.83) .505 (7.24) .285 –54 (14.10) .555 (8.51) .335 –55 (15.49) .610 (9.91) .390 –56 (15.88) .625 (10.29) .405 –57 (16.51) .650 (10.92) .430 –58 (17.91) .705 (12.32) .485 –59 (19.18) .755 (13.59) .535 –60 (20.96) .825 (15.37) .605 C D RA LEAD STYLE D –01 (5.84) .230 –02 (2.54) .100 –03 (3.18) .125 (3.05) .120 (4.45) .175 (3.05) .120 A A DOUBLE ROW SINGLE ROW C B C Important Note: Style -02 does not mate with SMS Series. –D T/H LEAD STYLE B MOQ Required = Rightangle = Double Row –G (2.48) .098 Other Plating –RA = Single Row = 10 µ" (0.25 µm) Gold on post, Gold flash on tail Lead–Free Solderable: Yes OPTION –S = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail PROCESSING ALSO AVAILABLE - HTMS —D BODY DESIGN D —S–RA —D–RA samtec.com?TMS or samtec.com?HTMS Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
HTMS-112-56-G-S
物料型号:TMS/HTMS系列 器件简介:1.27毫米间距的通孔微头,兼容SMS, SLM, RSM系列。 引脚分配:支持1至50排引脚,具体引脚数和排列方式可以根据图表指定。 参数特性:绝缘体材料为黑色液晶聚合物,端子材料为磷青铜,镀层为金或锡,额定电流为每针5A(2针供电),工作温度范围为-55°C至+105°C(锡镀层)或-55°C至+125°C(金镀层)。 功能详解:文档提供了不同引脚排列和长度的详细规格,包括直角和直插两种引脚样式。 应用信息:文档未明确提供应用信息,但根据物料型号参数特性,可能用于需要高电流和高温耐受的电子设备。 封装信息:文档提供了不同引脚排列和长度的封装选项,包括单排和双排设计。
HTMS-112-56-G-S 价格&库存
很抱歉,暂时无法提供与“HTMS-112-56-G-S”相匹配的价格&库存,您可以联系我们找货
