HTST-107-04-L-D-RA
HTST-107-04-L-D-RA
    SAMTEC(申泰)
    HIGH TEMP TOP SHROUD
HTST-107-04-L-D-RA 数据手册
SHROUDED .025" SQ POST IDC HEADERS (2.54 mm) .100" PITCH • TST/HTST/ZST SERIES TST/HTST/ZST Mates: IDSD, HCSD SPECIFICATIONS Insulator Material: TST, ZST=Black Glass Filled Polyester HTST=Natural LCP Insulation Resistance: 5000 MΩ min Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Voltage Rating:: 425 VAC/600 VDC SERIES -1 TST - NO. PINS PER ROW LEAD STYLE 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 = Cable Strip HTST LEAD THROUGHHOLE STYLE (A) –01 (2.92) .115 –02 (4.19) .165 –03 (14.35) .565 = Gold flash on post, Matte Tin on tail (Not available on –DV) (2.54) .100 x No. of Positions + (7.62) .300 MOQ Required Other platings & sizes Alignment Pins Single Row Locking Leads Polarized Surface Mount (lead style –01 only) (HTST only) –DV = Pick & Place Pad –P –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) = Double Row Right-angle (lead style –04 & –05 only) –T (9.27) .365 —D —DV —D—RA B LEAD RIGHTSTYLE ANGLE (B) (10.16) .400 (8.89) .350 A (11.18) .440 ZST —DV (HTST ONLY) -1 NO. PINS PER ROW - 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 LEAD STYLE Specify LEAD STYLE from chart (Standard sizes) (2.54) .100 x No. of Positions + (7.62) .300 - PLATING OPTION –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail (9.27) .365 (2.29) .090 MIN (2.54) .100 - D BODY HEIGHT C (OAL) –04 (3.30) .130 –05 (5.84) .230 - –F = Matte Tin (8.89) .350 —D—RA BODY HEIGHT –“XXXX” = Gold flash on post, Matte Tin on tail –T (2.54) .100 x No. of Positions + (5.08) .200 Note: Some lengths, styles and options are non-standard, non-returnable. ZST is non-standard, non-returnable. –D –D–RA = Matte Tin —D ALSO AVAILABLE OTHER OPTION = Double Row Surface Mount (lead style –01 only) (HTST only) = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail (2.54) .100 x No. of Positions + (5.08) .200 - ROW OPTION = Double Row Through-hole (lead style –01, –02 & –03 only) –L PROCESSING Lead–Free Solderable: HTST=Yes TST, ZST= No, Lead Wave only SMT Lead Coplanarity: (0.10 mm) .004" max (05-15) (0.15 mm) .006" max (17-36)* *(.004" stencil solution may be available; contact ipg@samtec.com) - PLATING OPTION –F Specify LEAD STYLE from chart (Standard sizes) = High Temp Cable Strip - = Body Height LEAD STYLE C (OAL) MAX BODY HEIGHT –01 (16.00) .630 (13.72) .540 –02 (18.54) .730 (16.26) .640 –03 (21.08) .830 (18.80) .740 –04 (23.62) .930 (21.34) .840 –05 (26.16) 1.030 (23.88) .940 –06 (28.70) 1.130 (26.42) 1.040 –07 (31.24) 1.230 (28.96) 1.140 –08 (33.78) 1.330 (31.50) 1.240 –09 (36.32) 1.430 34.04) 1.340 Note: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. samtec.com?TST, samtec.com?HTST or samtec.com?ZST Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
HTST-107-04-L-D-RA
物料型号:FLEX STACK SHROUDED IDC HEADERS,有TST、HTST和ZST型号。
器件简介:这些是带有0.025英寸方形引脚的IDC头,间距为2.54毫米,引脚间距为0.100英寸。
引脚分配:文档中没有提供具体的引脚分配图,但提到了单排和双排选项。
参数特性: - 绝缘材料:TST和ZST为黑色玻璃填充聚酯,HTST为天然LCP。 - 绝缘电阻:至少5000 MΩ。 - 端子材料:磷青铜。 - 镀层:金或锡,厚度为50微英寸(1.27微米)的镍层上镀金或锡。 - 工作温度范围:HTST为-55°C至+125°C,TST和ZST为-55°C至+105°C。 - 电压等级:425 VAC/600 VDC。
功能详解:文档中没有提供详细的功能解释,但提到了不同的引脚样式和选项,如表面安装、直插式和直角引脚。
应用信息:文档中没有提供具体的应用信息,但根据其特性,这些连接器可能适用于需要高温耐受性和良好绝缘电阻的应用。
封装信息:提供了不同引脚样式的尺寸和最大体高,以及最小订购数量要求。
HTST-107-04-L-D-RA 价格&库存
很抱歉,暂时无法提供与“HTST-107-04-L-D-RA”相匹配的价格&库存,您可以联系我们找货
