ASP-134486-01
ASP-134486-01
    SAMTEC(申泰)
    P=1.27mm
    板对板连接器 针脚数:400Pin 间距:1.27mm 排数:10
ASP-134486-01 数据手册
REVISION N DO NOT SCALE FROM THIS PRINT NOTES: 1. VITA 57 CONNECTOR. 2. C REPRESENTS A CRITICAL DIMENSION. 3. MINIMUM PUSHOUT FORCE: 0.50 LBS. 4. PARTS TO BE PACKAGED IN TAPE & REEL. 5. DIMENSION C12 MUST BE MEASURED IN THE FOUR OUTSIDE CORNERS USING INSPECTION FIXTURE AT-1817-836-2, USE CO-AU-WI-2003-M FOR PROCESS. 6. MAXIMUM ROW TO ROW VARIATION .003[0.08], MEASURED FIRST & LAST POSITIONS ONLY, ALL ROWS. 7. NOTE DELETED. 8. SOLDER CHARGE VOLUME IS .00000891 CUBIC INCHES (REF). 9. ATTACH LABEL "SEAX-001" TO TAPE & REEL PACKAGE. 2.229 56.62 REF (40 POS X .050[1.27]+.229[5.82]) C 1.9500 49.530 (TYP) C .156 3.96 REF .009[0.23] 2 .0500 1.270 (TYP) .404 10.25 .100 2.54 (TYP) REF C 40 K J H G F E D C B A .461 11.71 REF 2.170 55.12 REF .035 0.90 REF 1 CL .300 7.62 REF .017 0.42 REF "B" C C .258 6.55 REF (INCLUDES K-DOT) .050 1.27 REF 1.9500 49.530 .0175±.0030 0.445±0.076 REF .050 1.27 REF (TYP) .0530-.0645 ([1.346]-[1.638]) (TYP) .040 1.02 REF "B" .050 1.27 (TYP) .044 1.12 REF C .035±.005 0.89±0.13 (TYP) 01 3 C C DETAIL 'C' SCALE 6 : 1 .033 0.84 REF C .059±.020 1.49±0.51 .002±.003 0.05±0.08 (SEE NOTES 5 & 6) .011 0.28 REF .930±.020 23.62±0.51 .033 0.84 REF .521 13.23 REF C C .0355-.0470 ([.902]-[1.194])(TYP) 'C' C 2.1410 54.381 REF SECTION "B"-"B" SCALE 2.5 : 1 'A' .120 3.05 REF C .034 0.86 REF .044 1.12 REF CL DETAIL 'A' SCALE 3.5 : 1 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: ITEM NO. PART NUMBER QUANTITY MATERIAL 1 SEAF-40-06.5-10-A 1.0000 LCP, UL 94 V0, COLOR: BLACK 2 NEW-SUB-C-209-06.5-S-2 400.00 COPPER ALLOY\LEAD FREE SOLDER 3 K-DOT-.404-.500-.005 1.0000 POLYIMIDE FILM 4 CT-SEAF028MS .00500 CONDUCTIVE POLYMER 5 SEAX-0001 .00500 LABEL DECIMALS ANGLES .XX: .01[.3] .XXX: .005[.13] .XXXX: .0020[.051] 2 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 PITCH SOCKET ARRAY ASSEMBLY PLATING: CONTACT AREA: .000030 GOLD OVER .000050 NICKEL REMAINDER: .000200 REF TIN OVER .000050 NICKEL DWG. NO. F:\DWG\MISC\MKTG\ASP-134486-01-MKT.SLDDRW BY: G. PURVIS ASP-134486-01 11/09/2007 SHEET 1 OF 4 ASP-134486-01 REVISION N RECOMMENDED PCB LAYOUT 1.950 49.53 .16 4.0 REF .12 3.1 REF CONNECTOR ASSEMBLY OUTLINE .0500 1.270 (TYP) 40 CL .03 0.8 REF K J H G .521 13.23 REF F CL .450 11.43 .22 5.7 E D C .120 3.05 B A .025 0.64 (TYP) (SURFACE MOUNT PAD) .0955 2.426 01 .050 1.27 (2 PLCS) NPTH 2.141 54.38 ALL DIMENSIONS ARE SYMMETRIC ABOUT THE CENTERLINE. PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 PITCH SOCKET ARRAY ASSEMBLY DWG. NO. F:\DWG\MISC\MKTG\ASP-134486-01-MKT.SLDDRW ASP-134486-01 BY: G. PURVIS 11/09/2007 SHEET 2 OF 4 ASP-134486-01 REVISION N RECOMMENDED STENCIL LAYOUT NOTE: STENCIL TO BE .0060[.152] THICK. 1.950 49.53 .0500 1.270 (TYP) CL 40 K J H G F CL E .450 11.43 D C B A 01 .035 0.89 (TYP) ALL DIMENSIONS ARE SYMMETRIC ABOUT THE CENTERLINE. PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 PITCH SOCKET ARRAY ASSEMBLY DWG. NO. F:\DWG\MISC\MKTG\ASP-134486-01-MKT.SLDDRW ASP-134486-01 BY: G. PURVIS 11/09/2007 SHEET 3 OF 4 ASP-134486-01 A REVISION N 01 2.835 72.00 REF 4 40 "D" "D" .945 24.00 REF (TYP) USER DIRECTION OF UN-REELING POCKET NOT DETAILED PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. SECTION "D"-"D" SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 PITCH SOCKET ARRAY ASSEMBLY DWG. NO. PACKAGING VIEW F:\DWG\MISC\MKTG\ASP-134486-01-MKT.SLDDRW ASP-134486-01 BY: G. PURVIS 11/09/2007 SHEET 4 OF 4
ASP-134486-01 价格&库存
很抱歉,暂时无法提供与“ASP-134486-01”相匹配的价格&库存,您可以联系我们找货
ASP-134486-01
  • 1+116.20840
  • 10+111.53380
  • 30+103.43900
  • 100+96.36340
库存:127
ASP-134486-01
  • 1+151.80000
  • 10+141.90000
  • 50+134.20000
  • 100+128.70000
  • 200+125.40000
  • 400+123.20000
库存:370
