CES-129-01-T-D
CES-129-01-T-D
    SAMTEC(申泰)
    CONN RCPT 58POS .100" DUAL TIN
CES-129-01-T-D 数据手册
F-215 SLW–110–01–T–D CES–125–02–L–D SLW–120–01–G–S CES–115–01–T–S (2,54 mm) .100" SLW, CES SERIES LOW PROFILE SOCKET STRIPS SPECIFICATIONS For complete specifications see www.samtec.com?SLW or www.samtec.com?CES Insulator Material: Black G.F. Polyester Contact Material: Phosphor Bronze Plating: Au or Sn over 50µ"(1,27 µm) Ni SLW Current Rating (SLW/TSW): 5.2 A per pin (1 pin powered per row) CES Current Rating (TSW/CES): 5.5 A per pin (1 pin powered per row) Voltage Rating: SLW: 406 VAC CES: 400 VAC Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Contact Resistance: 10 mΩ Insertion Depth: SLW: (2,16 mm) .085" to (2,92 mm) .115" CES: (2,62 mm) .103" to (4,06 mm) .160" Insertion Force: SLW: (Single contact only) (3,34 N) 12 oz avg. (0,64 mm) .025" SQ pin CES: (Single contact only) (2,22 N) 8 oz avg. (0,64 mm) .025" SQ pin Withdrawal Force: SLW: (Single contact only) (1,67 N) 6 oz avg. (0,64 mm) .025" SQ pin CES:(Single contact only) (1,11 N) 4 oz avg. (0,64 mm) .025" SQ pin RoHS Compliant: Yes Lead-Free Solderable: Wave only RECOGNITIONS NO. PINS PER ROW 1 SLW PLATING OPTION 01 ROW OPTION Mates with: TLW, TSW, MTLW, MTSW, HW, EW, ZW, HTSW, HMTSW, TSM –S = Single Row –F 01 thru 50 –D = Gold flash on contact, Matte Tin on tail = Double Row (2,54) .100 X No. of Positions 01 02 –L (2,54) .100 = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail (2,54) .100 TYP 02 –G (2,54) (4,95) .100 .195 = 20µ" (0,51 µm) Gold on contact, Gold flash on balance 01 –T (4,57) .180 = Matte Tin (2,92) .115 (0,64) .025 (2,54) .100 1 CES (0,41) .016 NO. PINS PER ROW Mates with: TLW, TSW, MTLW, MTSW, HW, EW, ZW, DW, HTSW, PHT, HMTSW For complete scope of recognitions see www.samtec.com/quality LEAD STYLE – 01 01 thru 50 –L = (3,25 mm) .128 “A” Dim. = 10µ" (0,25 µm) Gold contact, Matte Tin on tail – 02 = (5,66 mm) –T .223 “A” Dim. (2,54) .100 X No. of Positions PLATING OPTION = Matte Tin ROW OPTION –S – RA = Single Row = Right Angle version –D Style – 02 only Single Row only = Double Row (3,05) .120 01 02 (3,05) .120 FILE NO: 090871_0_000 (CES ONLY) (2,54) .100 TYP ALSO AVAILABLE (0,71) .028 SQ 02 (MOQ Required) • Other platings Contact Samtec. (1,02) .040 A (2,54) (5,59) .100 .220 Chamfered (0,25) .010 Dual leaf folded contact 01 (5,08) .200 Note: Some lengths, styles and options are non-standard, non-returnable. (0,51) .020 (0,64) .025 RA OPTION (2,54) .100 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. Closed bottom contact
CES-129-01-T-D
1. 物料型号:SLW–110–01–T–D、CES–125–02–L–D、CES–115–01–T–S、SLW–120–01–G–S。 2. 器件简介:这些是低剖面插座条,用于电子设备中,提供不同型号和配置。 3. 引脚分配:文档中没有明确提供引脚分配的详细信息,但提到了不同型号的引脚数量。 4. 参数特性: - 绝缘体材料:黑色G.F.聚酯。 - 接触材料:磷青铜。 - 镀层:金或锡,覆盖50µ"(1.27 µm)镍。 - 电流额定值:SLW/TSW每针5.2A(每行1针供电),CES/TSW每针5.5A(每行1针供电)。 - 电压额定值:SLW 406 VAC,CES 400 VAC。 - 工作温度范围:金镀层-55°C至+125°C,锡镀层-55°C至+105°C。 - 接触电阻:10 mΩ。 - 插入深度:SLW 0.085"至0.115",CES 0.103"至0.160"。 - 插入力和拔出力:SLW和CES的单针平均值分别列出。 5. 功能详解:文档提供了插座条的电流和电压额定值,以及它们在不同温度下的性能。 6. 应用信息:适用于需要低剖面插座条的电子设备。 7. 封装信息:提供了不同型号的尺寸和形状信息,以及与不同系列插座条的兼容性。
CES-129-01-T-D 价格&库存
很抱歉,暂时无法提供与“CES-129-01-T-D”相匹配的价格&库存,您可以联系我们找货
CES-129-01-T-D
  • 1+68.744161+8.91056
库存:1
