CLP-116-02-L-D-BE
CLP-116-02-L-D-BE
    SAMTEC(申泰)
    .050" X .050
CLP-116-02-L-D-BE 数据手册
LOW PROFILE DUAL WIPE SOCKET 8 (1.27 mm) .050" PITCH • CLP SERIES CLP Mates: FTSH, FTS, FW CLP -1 - 02 - NO. PINS PER ROW 02 thru 50 SPECIFICATIONS G b p s PLATING OPTION - ROW OPTION –F –D = Gold flash on contact, Matte Tin on tail Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (CLP/FTSH): 3.4 A per pin (2 pins powered) Voltage Rating: 280 VAC/395 VDC Operating Temp Range: -55 °C to +125 °C Insertion Depth: Top Entry = (1.40 mm) .055" minimum Bottom Entry = (2.41 mm) .095" minimum plus board thickness DH Entry = (2.31 mm) .091" to (2.67 mm) .105" Max Cycles: 100 with 10 µ" (0.25 µm) Au - –BE = Double Row = Bottom Entry (Required for bottom entry applications) –DH –A = Double Horizontal (Requires FTSH–04 lead style) –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail OTHER OPTIONS = Alignment Pin (Not available with –PA option) (05, 06, 07, 08, 10, 12, 15, 20, 25, 30, 40 positions only) (–DH option and other sizes. Contact Samtec.) –K –G = (4.00 mm) .157" DIA Polyimide film Pick & Place Pad = 10 µ" (0.25 µm) Gold (–D only) –P = Pick & Place Pad (5 positions min. –D only) (Not always necessary for auto placement. See Flex Processing.) –PA = Pick & Place Pad with Alignment Pin (–D only) (Not available with –A option) PROCESSING –TR Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (02-35) (0.15 mm) .006" max (36-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) = Tape & Reel 1RRI3RVLWLRQV[     –FR         = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) ALSO AVAILABLE MOQ Required Single row Other platings —DH —D 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT HIGH MATING CYCLES Notes: Severe Environment Testing qualified; aligns with MIL-DTL-55302. Visit samtec.com/set PIN/ROW A 04-15 (3.56) .140 16-50 (7.11) .280 $ If odd pins/row, alignment pins are on middle position on centerline of the part. If even pins/row, then alignment pins are between middle two positions. —PA OPTION —P OPTION Some lengths, styles and options are non-standard, non-returnable. F-224 samtec.com?CLP Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
CLP-116-02-L-D-BE
物料型号:TIGER" CLAW LOW PROFILE DUAL WIPE SOCKET
器件简介:这是一个低剖面双擦洗插座,适用于8个引脚的配置,具有1.27毫米的间距。
引脚分配:文档中没有明确提供引脚分配的具体信息,但提到了引脚数量范围是2至50。
参数特性: - 绝缘体材料:黑色液晶聚合物 - 接触材料:磷青铜 - 镀层:锡或金,覆盖在50微米(1.27微米)镍上 - 电流额定值:每针3.4安培(2针供电) - 电压额定值:280 VAC/395 VDC - 工作温度范围:-55°C至+125°C - 插入深度:顶入式至少1.40毫米,底入式至少2.41毫米,加上板厚;DH入式从2.31毫米到2.67毫米
功能详解:文档中没有提供详细的功能解释,但提到了该插座具有高插拔周期和长寿命。
应用信息:文档中没有提供具体的应用信息
封装信息:提供了多种选项,包括镀金、镀锡、双行、底入式等,以及一些特定的加工选项,如Pick & Place Pad和对齐销。
CLP-116-02-L-D-BE 价格&库存
很抱歉,暂时无法提供与“CLP-116-02-L-D-BE”相匹配的价格&库存,您可以联系我们找货
