ESD-113-T-04
ESD-113-T-04
    SAMTEC(申泰)
    插件,P=2.54mm
    排母 间距:2.54mm 2x13P 直插
ESD-113-T-04 数据手册
F-224 WEB SS–132–G–2 ESD–115–TT–05 SS, SD, ESD, ESS, HSS SERIES (2.54 mm) .100" PRECISION MACHINED SOCKET STRIPS Mates with: TS, TD, HTS, BBS, BBD, BBL, BDL, BHS TYPE STRIP NO. PINS PER ROW 1 LEAD STYLE PLATING OPTION OTHER OPTION OPTION SPECIFICATIONS For complete specifications see www.samtec.com?SS, www.samtec.com?ESS, www.samtec.com?SD, www.samtec.com?ESD or www.samtec.com?HSS Insulator Material: SS, SD, ESS, ESD= Black G.F. Polyester HSS= Black Liquid Crystal Polymer Contact: BeCu Shell: Brass except Style 5A Phosphor Bronze Plating: Au over 50 µ" (1.27 µm) Ni or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C Lead Size Range: (0.38 mm to 0.56 mm) .015" to .022" DIA and most IC leads RoHS Compliant: Yes Lead-Free Solderable: SS, SD, ESS, ESD: No, Lead Wave only HSS: Yes 01 thru 32 =SS, ESS Series 01 thru 36 =HSS, SD & ESD Series SS HSS –T –TT (4.90) .193 (1.32) .052 DIA (2.54) .100 x No. of Positions (2.54) .100 (2.54) .100 ESD (2.54) .100 x No. of Positions = (5.08) Standard .200 Row Socket –03, –04, –05 For LIF specify –23 (ESS, ESD) (1.83) .072 DIA (2.54) .100 (2.54) Double .100 TYP • Locking lead option on ESS and ESD series For LIF specify –21A, –21B or –21C (SS, HSS, SD) (2.54) .100 TYP SD (MOQ Required) –1A, –1B OR –1C (2.54) .100 x No. of Positions (2.54) .100 ALSO AVAILABLE LIF= Low Insertion Force (2.54) .100 N/A Style –5A Requires -T Plating Option = Tin contact and shell (Styles 1, 2, 4, and 05 except LIF N/A) Styles –5A & –05 socket heads not countersunk. (0.76) .030 REF (7.62) .300 (3.43) .135 = 30 µ" (0.76 µm) Gold contact, 10 µ" (0.25 µm) Gold shell = Elevated Single Row Socket –N = Non Flush Locking = Socket Add –L suffix for locking lead socket in end positions. Requires Style -2 or -22 and .035" ± .003 DIA board hole. = 30 µ" (0.76 µm) Gold contact, Tin shell ESS FILE NO. E111594 –L = 10 µ" (0.25 µm) Gold contact, Tin shell (Styles 2 & 22 only) –G = Standard = High Temp Single Row Socket Single Row Socket RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –S (0.76) .030 LEAD STYLE –1A or –21A Y = Elevated Double (2.54) Row Socket .100 –1B or –21B (0.64) .025 SQ (2.54) Style .100 –5A not available. TYP Styles –5A & –05 socket heads not countersunk. –1C or –21C Y (9.14) .360 (12.95) .510 (6.60) .260 (0.76) .030 B A C (0.64) .025 SQ –2, –22*,–5A, or –38* *For LIF specify –22 or –38 (SS, HSS, SD) (2.54) .100 x No. of Positions (2.54) .100 TYP (2.54) .100 Note: Some lengths, styles and options are non-standard, non-returnable. (1.83) .072 DIA (2.54) .100 (5.08) .200 (0.76) .030 (1.32) .052 DIA Z Y X LEAD STYLE –2 or –22 –38 –5A X DIA Y Z (0.51) (3.18) (7.62) .020 .125 .300 (0.51) (4.57) (8.89) .020 .180 .350 (0.89) (12.95) (17.86) .035 .510 .703 LEAD STYLE –05 –03 or –23 –04 A B C (17.86) (13.46) (4.39) .703 .530 .173 (11.51) (8.38) (3.12) .453 .330 .123 (14.05) (10.92) (3.12) .553 .430 .123 Locking lead available. See OPTION. WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
ESD-113-T-04
物料型号:ESD-115-TT-05
器件简介:这是一种精密机加工的插座条,适用于多种电子应用。
引脚分配:文档提供了不同引脚样式和尺寸的详细信息,包括引脚直径、X和Y方向的尺寸以及Z方向的长度。
参数特性:包括接触材料为铍铜,外壳材料为黄铜(除了5A样式使用钯青铜),以及镀层信息,如金上镀50微米镍或锡上镀50微米镍。
功能详解:文档详细描述了插座条的多种选项,如锁定引脚选项、不同的镀金接触和外壳材料。
应用信息:这些插座条适用于多种电子设备,具有不同的操作温度范围(-55°C至+125°C)和引脚尺寸范围。
封装信息:提供了不同样式的引脚和插座头的详细尺寸,以及它们与哪些其他Samtec产品兼容。
ESD-113-T-04 价格&库存
很抱歉,暂时无法提供与“ESD-113-T-04”相匹配的价格&库存,您可以联系我们找货
