ESQ-118-12-G-T
ESQ-118-12-G-T
    SAMTEC(申泰)
    ELEVATED SOCKET STRIPS
ESQ-118-12-G-T 数据手册
ESQ–132–14–G–D F-215 ESQ–110–44–T–D ESW–115–12–G–S (2,54 mm) .100" ESW, ESQ SERIES ELEVATED SOCKET Mates with: TSW, MTSW, EW, MTLW, TSS, ZSS, TSM, DW, ZW, HW, TSSH, HTSS SPECIFICATIONS For complete specifications see www.samtec.com?ESW or www.samtec.com?ESQ Insulator Material: Black Glass Filled Polyester Contact Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Current Rating (ESW/TSW): 5.2 A per pin (1 pin powered per row) Current Rating (ESQ/TSW): 5.7 A per pin (1 pin powered per row) Voltage Rating: 550 VAC mated with TSW or ESQ Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Contact Resistance: 10 mΩ Insertion Depth: (3,68 mm) .145" to (6,35 mm) .250" Insertion Force: (Single contact only) Standard = 6 oz (1,67 N) avg. ((0,64 mm) .025" SQ pin); ESW Low Inser tion Force= 3 oz (0,83 N) avg. ESQ Low Insertion Force= 3.3 oz (0,92 N) avg. Normal Force: Standard = 125 grams (4,4 N) Withdrawal Force: (Single contact only) Standard = 5 oz (1,39 N) avg. ((0,64 mm) .025" SQ pin); ESW Low Inser tion Force= 2.6 oz (0,72 N) avg. ESQ Low Insertion Force= 2.9 oz (0,81 N) avg. Max Cycles: 100 with 10µ" (0,25 µm) Au RoHS Compliant: Yes Lead-Free Solderable: Wave only TYPE STRIP 1 NO. PINS PER ROW LEAD STYLE PLATING OPTION ROW OPTION –S ESW = Single Row –L = Solder Tail = 10µ" (0,25 µm) Gold contact, Matte Tin on tail ALSO AVAILABLE ESQ (MOQ Required) = Square Tail • Other platings Contact Samtec. –D –G –T = Triple Row (ESQ only) –T 01 thru 36 = Matte Tin (N/A w/LIF contact) Two leads per strip crimped. N/A with single row 1 or 2 positions. –“XXX” = Polarized (2,54) .100 X No. of Positions + (0,51) .020 (2,41) .095 –S 01 36 (2,54) .100 72 02 LOW STANDARD INSERTION FORCE INSERTION FORCE 01 (2,54) .100 108 03 (5,08) .200 (2,54) .100 (ESQ only) Specify LEAD STYLE from chart below. (4,95) .195 (2,54) .100 71 –T –LL = Locking Lead = Double Row = 20µ" (0.51 µm) Gold contact, Gold Flash on Balance –D OTHER OPTION (7,49) .295 106 01 – 12 – 37 – 13 – 38 – 23 – 48 – 33 – 58 – 14 – 39 – 24 – 49 – 34 – 59 – 44 – 69 A (2,29) .090 (7,36) .290 (4,83) .190 (2,29) .090 (12,19) .480 (9,65) .380 (7,11) .280 (4,57) .180 B (11,05) .435 (13,59) .535 (16,13) .635 (11,05) .435 (13,59) .535 (16,13) .635 (18,67) .735 B A APPLICATIONS RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality FILE NO: 090871_0_000 Note: Some lengths, styles and options are non-standard, non-returnable. (2,54) .100 TYP ESW (0,41) x (0,79) .016 .031 ESQ (0,64) .025 SQ Self g Nestkinets Soc (ESQ Series) PC/104™ J1/P1 “Stackthrough” Connectors Standard Insertion Force ESQ-132-14-G-D Low Insertion Force ESQ-132-39-G-D PC/104™ J1 “Non-Stackthrough” Connectors Standard Insertion Force ESQ-132-12-G-D Low Insertion Force ESQ-132-37-G-D PC/104™ J2/P2 “Stackthrough” Connectors Standard Insertion Force ESQ-120-14-G-D Low Insertion Force ESQ-120-39-G-D PC/104 is a trademark of the PC/104 Consortium. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
ESQ-118-12-G-T
1. 物料型号:Samtec ESQ–132–14–G–D, ESQ–110–44–T–D, ESW–115–12–G–S 2. 器件简介:文档描述了Samtec的ESW和ESQ系列的插座,这些插座与TSW, MTSW, EW, MTLW, TSS, ZSS, TSM, DW, ZW, HW, TSSH, HTSS等系列的插头兼容。 3. 引脚分配:文档中提到了不同型号的插座,但没有具体说明每个型号的引脚分配。 4. 参数特性: - 引脚数量:1排,每排1个引脚。 - 接触材料:磷青铜,镀金或锡。 - 额定电流:ESW/TSW为每针5.2A(每排1针供电),ESQ/TSW为每针5.7A(每排1针供电)。 - 电压等级:与TSW或ESQ配合使用时为550V AC。 - 操作温度范围:-55°C至+125°C(金接触),-55°C至+105°C(锡接触)。 - 插入深度:3.68mm至6.35mm。 - 插入力:标准为6盎司(1.67N),ESW低插入力为3盎司(0.83N)。 - 正常力:标准为125克(4.4N)。 - 拔出力:标准为5盎司(1.39N),ESW低插入力为2.6盎司(0.72N)。 5. 功能详解:文档提供了插座的详细规格和选项,包括引脚样式、接触材料、镀层选项等。 6. 应用信息:适用于C/104标准,提供了不同插入力的插座选项。 7. 封装信息:文档中没有提供封装信息
ESQ-118-12-G-T 价格&库存
很抱歉,暂时无法提供与“ESQ-118-12-G-T”相匹配的价格&库存,您可以联系我们找货
ESQ-118-12-G-T
  • 12+93.7665612+12.11926
