ESQ–110–44–T–D
F-212
(2,54mm) .100"
ESQ–132–14–G–D
ESW–115–12–G–S
ESW, ESQ SERIES
ELEVATED SOCKET
Mates with:
TSW, MTSW, EW, MTLW,
TSS, ZSS,
TSM, DW, ZW, HW
SPECIFICATIONS
For complete specifications
see www.samtec.com?ESW
or www.samtec.com?ESQ
Insulator Material:
Black Glass Filled
Polyester
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50µ" (1,27µm) Ni
Voltage Rating:
550 VAC mated with
TSW or ESQ
Operating Temp Range:
-55°C to +125°C with Gold
-55°C to +105°C with Tin
Contact Resistance:
10 mΩ max
Insertion Depth:
(3,68mm) .145" to
(6,35mm) .250"
Insertion Force:
(Single contact only)
Standard = 6oz (1,67N) avg.
((0,64mm) .025" SQ pin);
ESW Low Inser tion Force=
3oz (0,83N) avg.
ESQ Low Insertion Force=
3.3oz (0,92N) avg.
Normal Force:
Standard = 125 grams (4,4N)
Withdrawal Force:
Standard = 5oz (1,39N) avg.
2.6oz (0,72N) avg.
2.9oz (0,81N) avg.
Max Cycles:
100 with 10µ" (0,25µm) Au
RoHS Compliant:
Yes
Lead-Free Solderable:
Wave only
TYPE
STRIP
NO. PINS
PER ROW
1
ESW
LEAD
STYLE
PLATING
OPTION
ESQ
= Square Tail
20°C
6.9A
40°C
6.0A
60°C
5.3A
= 10µ" (0,25µm)
Gold contact,
Matte Tin on tail
–T
(2,54)
.100
–“XXX”
= Polarized
Note: Other Gold plating
options available.
Contact Samtec.
02
Specify LEAD STYLE
from chart below.
(4,95)
.195
–D (2,54)
.100
LOW
STANDARD
INSERTION FORCE INSERTION FORCE
01
(2,54)
.100
108
03
(5,08)
.200 (2,54)
.100
–T
Two leads per
strip crimped.
N/A with single
row 1 or 2
positions.
36
72
(ESQ
only)
–T
= Triple
Row
(ESQ only)
= Matte Tin
(N/A w/LIF contact)
(2,41)
.095
71
–D
–G
(2,54) .100 X No. of Positions + (0,51) .020
–LL
= Locking
Lead
= Double
Row
= 20µ" (0.51µm)
Gold contact,
Gold Flash on Balance
01 thru 36
01
= Single
Row
–L
95°C
3.5A
6 POSITIONS (2x3) POWERED
–S
OTHER
OPTION
–S
CURRENT RATING
ESW mated
AMBIENT
with TSW
TEMP
= Solder Tail
ROW
OPTION
(7,49)
.295
106
01
– 12
– 37
– 13
– 38
– 23
– 48
– 33
– 58
– 14
– 39
– 24
– 49
– 34
– 59
– 44
– 69
A
(2,29)
.090
(7,36)
.290
(4,83)
.190
(2,29)
.090
(12,19)
.480
(9,65)
.380
(7,11)
.280
(4,57)
.180
B
(11,05)
.435
(13,59)
.535
(16,13)
.635
(11,05)
.435
(13,59)
.535
(16,13)
.635
(18,67)
.735
B
A
APPLICATIONS
Note: Some lengths,
styles and options are
non-standard, non-returnable.
(2,54)
.100
TYP
ESW
(0,41) x (0,79)
.016 .031
ESQ
(0,64)
.025
SQ
Self g
Nestkinets
Soc
(ESQ Series)
WWW.SAMTEC.COM
PC/104™ J1/P1 “Stackthrough” Connectors
Standard Insertion Force
ESQ-132-14-G-D
Low Insertion Force
ESQ-132-39-G-D
PC/104™ J1 “Non-Stackthrough” Connectors
ESQ-132-12-G-D
Low Insertion Force
ESQ-132-37-G-D
PC/104™ J2/P2 “Stackthrough” Connectors
ESQ-120-14-G-D
Low Insertion Force
ESQ-120-39-G-D
PC/104 is a trademark of the PC/104 Consortium.
