ESQT–125–02–L–Q–465
F-218 (Rev 10OCT17)
ESQT–115–02–GF–D–600
ESQT–125–03–M–Q–310
(2.00 mm) .0787"
ESQT SERIES
FLEXIBLE ELEVATED SOCKET STRIPS
SPECIFICATIONS
For complete specifications
see www.samtec.com?ESQT
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating (ESQT/TMMH):
4.5 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(2.62 mm) .103" to
(5.03 mm) .198" with
(0.38 mm) .015" wipe
Max Cycles:
100 with 10 µ" (0.25 µm) Au
RoHS Compliant:
Yes
Lead–Free Solderable:
Yes, for -S, -D & -Q
(Wave only for -T, -5 & -6)
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
High-retention
contacts
Board Mates:
TMMH, TMM, MTMM,
MMT, TW, LTMM, ZLTMM,
ESQT, PTT, TSH, TMMS
Cable Mates:
TCMD
APPLICATION
SPECIFIC OPTION:
NOTEBOOK 2.5" DISK
DRIVE INTERFACE
(2.00 mm)
.0787" pitch
Call for part number.
ESQT
1
NO. PINS
PER ROW
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
FILE NO. E111594
02 thru 50
Note:
This Series is non-standard,
non-returnable.
Surface
Mount
300
No. of positions x
(2.00) .0787 + (0.30) .012
OTHER
OPTION
–F
= Single
Row
–S
–“XXX”
–“XXX”
–L
= Double
Row
= Gold flash on contact,
Matte Tin on tail
(2.00) No. of
.0787 rows
TYP
x
(2.00)
.0787
295
–D
–T
= Triple
Row
–Q
= 20 µ" (0.51 µm)
Gold on contact,
Matte Tin on tail
06
See CLT Series.
01
See SMM Series.
= Quad
Row
–GF
See SQW Series.
(1.52)
.060
PC/104-PlusTM
Sockets
(0.50) .020 SQ
A
BODY
HEIGHT
= Body
Height
(in inches)
(7.87 mm)
.310"
minimum for
–S, –D, –Q
(9.53 mm)
.375"
minimum for
–T, –5, –6
= Five
Row
–6
= Six
Row
TAIL
(1.27)
.050
MIN
(2.00) .0787
Paste In Hole (PIH) processing.
Contact Samtec ASP Group.
(Not recommended for
stack through applications)
MAX MAX BODY
TAIL
HEIGHT
(13.72)
(20.32)
– 02 (21.59)
.850
.540
.800
(11.63) (3.76)
(10.36)
–03 .458 .148
.408
LEAD
STYLE
A
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
= Polarized
Position
(Indicate
position
number)
OTHER SOLUTIONS
–5
= 15 µ" (0.38 µm)
Gold on contact,
Gold flash on tail
(Recommended for
self-nesting)
(–02 lead style only)
(6.35)
.250
RightAngle
See ESQT-368
and PTHF Series.
BODY
HEIGHT
–M
Low
Profile
High
Reliability
ROW
OPTION
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
Other Solutions
See SQW and
TLE Series.
PLATING
OPTION
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
ESQT-105-03-F-S-335 价格&库存
很抱歉,暂时无法提供与“ESQT-105-03-F-S-335”相匹配的价格&库存,您可以联系我们找货
