ESQ–132–14–G–D
F-218 (Rev 10OCT17)
ESQ–110–44–T–D
ESW–115–12–G–S
(2.54 mm) .100"
ESW, ESQ SERIES
ELEVATED SOCKET
Mates with:
TSW, MTSW, EW,
MTLW, TSS, ZSS, TSM,
DW, ZW, HW, TSSH, HTSS
TYPE
STRIP
1
NO. PINS
PER ROW
LEAD
STYLE
PLATING
OPTION
ESW
SPECIFICATIONS
For complete specifications
see www.samtec.com?ESW or
www.samtec.com?ESQ
= Solder Tail
–S
–L
= Single
Row
–G
= Double
Row
= 10 µ" (0.25 µm)
Gold contact,
Matte Tin on tail
ESQ
Insulator Material:
Black Glass Filled Polyester
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (ESW/TSW):
5.2 A per pin
(2 pins powered)
Current Rating (ESQ/TSW):
5.7 A per pin
(2 pins powered)
Voltage Rating:
550 VAC mated with
TSW or ESQ
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Insertion Depth:
(3.68 mm) .145" to
(6.35 mm) .250"
Normal Force:
Standard = 125 grams (4.4 N)
Max Cycles:
100 with 10 µ" (0.25 µm) Au
RoHS Compliant:
Yes
Lead-Free Solderable:
Wave only
ROW
OPTION
= Square Tail
–T
= Triple
Row
(ESQ only)
–T
= Matte Tin
(N/A w/LIF contact)
(2.41)
.095
–S
01
36
(2.54)
.100
72
02
03
(5.08)
.200 (2.54)
.100
–T
(ESQ
only)
FILE NO. E111594
LOW
STANDARD
INSERTION FORCE INSERTION FORCE
01
(2.54)
.100
108
RECOGNITIONS
Specify LEAD STYLE
from chart below.
(4.95)
.195
(2.54)
.100
71
For complete scope
of recognitions see
www.samtec.com/quality
Two leads per
strip crimped.
N/A with single
row 1 or 2
positions.
–“XXX”
= Polarized
(2.54) .100 X No. of Positions + (0.51) .020
–D
–LL
= Locking
Lead
–D
= 20 µ" (0.51 µm)
Gold contact,
Gold Flash on Balance
01 thru 36
OTHER
OPTION
(7.49)
.295
106
01
– 12
– 37
– 13
– 38
– 23
– 48
– 33
– 58
– 14
– 39
– 24
– 49
– 34
– 59
– 44
– 69
A
(2.29)
.090
(7.36)
.290
(4.83)
.190
(2.29)
.090
(12.19)
.480
(9.65)
.380
(7.11)
.280
(4.57)
.180
B
(11.05)
.435
(13.59)
.535
(16.13)
.635
(11.05)
.435
(13.59)
.535
(16.13)
.635
(18.67)
.735
B
A
APPLICATIONS
ALSO AVAILABLE
(MOQ Required)
• Other platings
Contact Samtec.
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(2.54)
.100
TYP
ESW
(0.41) x (0.79)
.016 .031
ESQ
(0.64)
.025
SQ
Self g
Nestkinets
Soc
(ESQ Series)
PC/104™ J1/P1 “Stackthrough” Connectors
Standard Insertion Force
ESQ-132-14-G-D
Low Insertion Force
ESQ-132-39-G-D
PC/104™ J1 “Non-Stackthrough” Connectors
ESQ-132-12-G-D
Low Insertion Force
ESQ-132-37-G-D
PC/104™ J2/P2 “Stackthrough” Connectors
ESQ-120-14-G-D
Low Insertion Force
ESQ-120-39-G-D
PC/104 is a trademark of the PC/104 Consortium.
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
很抱歉,暂时无法提供与“ESW-108-33-S-S-LL”相匹配的价格&库存,您可以联系我们找货
