ET60S-D03-3-08-000-L-V1-S
    SAMTEC(申泰)
    ET60S SOCKET POWER ASSEMBLY
ET60S-D03-3-08-000-L-V1-S 数据手册
F-217 (Rev 13FEB17) ET60S–A04–5–03–D04–L–VP–S (5.50 mm) .217"(PWR) (2.54 mm) .100"(SIG) ET60S–D04–3–08–A04–L–V1–S ET60S SERIES VERTICAL POWER/SIGNAL SOCKET Mates with: ET60T POWER OPTION (RIGHT) ET60S SIGNAL POSITIONS PER ROW ROWS SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?ET60S –0 Insulator Material: Black LCP Terminal Material: Signal: Copper Alloy Power: Copper Alloy Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: Power: 60 A max per blade (2 pins powered @ 95 °C; 30 °C temperature rise) Signal: 2.8 A max (6 pins powered @ 95 °C; 30 °C temperature rise) Operating Temp Range: -40 °C to +105 °C RoHS Compliant: Yes –02, –04, –06, –08, –10, –12 = No Signal –AXX* = AC Power Positions (–02, –03, –04, –05, –06 positions only) (3 Row only) –3 –01, –02, –03, –04, –05, –06, –07, –08 = 3 Rows –DXX –5* = DC Power Positions ( –02, –03, –04, –05, –06, –07, –08, –09, –10 positions only) (5 Row only) = 5 Rows –00 –SXX* = No Signal = Split Power –000 Note: –AXX*, –SXX*, –5* & –T* are Preliminary = No Power A (2.54) .100 (7.50) .295 PROCESSING B C (5.50) .217 A POWER POWER POSITIONS POSITIONS AC (LEFT) (RIGHT) POWER Lead-Free Solderable: Yes (18.00) .709 RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality A + C + B + (33.98) 1.338 FILE NO. E111594 (2.60) .102 (4.81) .189 (3.00) .118 (5.17) .204 (0.64) .025 SQ ET60S–D03–3–08–A04–X–V1–S ALSO AVAILABLE (MOQ Required) A (2.00) .079 –02 –02 –03 –03 –04 –04 –05 –05 –06 –06 **(7.50) .295 **(15.00) .591 **(22.50) .886 **(30.00) 1.181 **(37.50) 1.476 –07 –07 N/A –08 –08 N/A –09 –09 N/A –10 –10 N/A D C TAIL –VP –V1 3 ROWS E F EXTreme Ten60Power™ is a trademark of Molex Incorporated and is dual sourced by Molex® (2.83) .111 (2.00) .079 (5.28) .208 (8.82) .347 ET60S–A04–5–03–D04–X–VP–S E (5.32) .209 (1.65) .065 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. 5 ROWS E F (2.83) (2.83) (2.50) (3.28) .111 .111 .098 .129 (2.60) N/A .102 A + C + D + (34.21) 1.347 (9.18) .361 (5.50) .217 (11.00) .433 (16.50) .650 **(22.50) .886 **(27.50) 1.083 **(33.00) 1.299 **(38.50) 1.516 **(44.00) 1.732 (49.50) 1.949 **Not Released • Increased creepage and clearance with the removal of contacts Contact Samtec. Notes: Some lengths, styles and options are non-standard, non-returnable. C DC POWER F (0.93) .037 (6.60) .260 ET60S–D04-5–03–A04–S–R1–S F-217 (Rev 13FEB17) ET60S–D04-3–08–A04–L–R1–S (5.50 mm) .217"(PWR) (2.54 mm) .100"(SIG) ET60S SERIES RIGHT-ANGLE POWER/SIGNAL SOCKET POWER OPTION (LEFT) PLATING –L –AXX* = AC Power Positions (–02, –03, –04, –05, –06 positions only) –DXX = DC Power Positions (–02, –03, –04, –05, –06, –07, –08, –09, –10 postions only) GUIDE POST TAIL –S –VP = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (Not available for 5 rows) = Vertical Press-fit = Side Guide Post –S = Vertical through-hole (Use with (1.60 mm) .062" thick card) (3 Row only) –V1 = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail –T* = Top Guide Post –R1 –SXX* = Right-angle through-hole (Use with (1.60 mm) .062" thick card) = Split Power –000 D A = No Power (2.00) .079 C Note: –AXX*, –SXX*, –5* & –T* are Preliminary A + D + C + (27.21) 1.071 (0.64) .025 SQ F A + D + C + (34.21) 1.347 SIGNAL POSITIONS PER ROW (3 Row) B *–02 (2.54) .100 *–04 (7.62) .300 *–06 (12.70) .500 –08 (17.78) .700 *–10 (22.86) .900 *–12 (27.94) 1.100 *Not Tooled **Not Released SIGNAL POSITIONS PER ROW (5 Row) **–01 N/A **–02 (2.00) .079 (4.00) .157 (6.00) .236 (8.00) .315 (10.00) .394 (12.00) .472 (14.00) .551 **–03 *–04 **–05 **–06 **–07 **–08 (3.33) .131 DIA D (4.94) .194 (5.50) .217 (5.50) .217 (5.27) .207 E ET60S–D04–5–03–A04–X–R1–S (7.50) .295 A (10.00) .394 A + B + C + (26.98) 1.062 (0.64) .025 SQ A + B + C + (33.98) 1.338 TAIL R1 E F (2.84) .112 (2.50) .098 (5.00) .197 (5.60) .220 (5.50) .217 (7.50) .295 (3.00) .118 (4.81) .189 (5.17) .204 (5.50) .217 (5.50) .217 (3.00) .118 ET60S–D03–3–08–A03–X–R1–S Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM (4.48) .176 (14.48) .570 C (5.50) .217 B (2.54) .100 (25.22) .993 All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
ET60S-D03-3-08-000-L-V1-S 价格&库存
很抱歉,暂时无法提供与“ET60S-D03-3-08-000-L-V1-S”相匹配的价格&库存,您可以联系我们找货
