FLEXIBLE .025" SQ
BOARD STACKERS
(2.54 mm) .100" PITCH • DW/EW/ZW SERIES
DW/EW/ZW
Board Mates:
SSW, SSQ, ESW, ESQ,
CES, SLW, BSW, BCS,
SSM, HLE, PHF
Cable Mates:
IDSS, IDSD
SPECIFICATIONS
Insulator Material:
Black Glass Filled Polyester
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
SERIES
DW
= (2.79 mm)
.110" Tail
NO. PINS
PER ROW
01 thru 50
EW
= (8.38 mm)
.330" Tail
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
PLATING
OPTION
–F
= Gold flash
on contact,
Matte Tin
on tail
–L
= 10 µ"
(0.25 µm)
Gold on
contact
area of
longer tail,
Matte Tin
on tail
ZW
= Custom
Tail
–G
= 10 µ"
(0.25 µm)
Gold on
contact
area of
longer tail,
Gold flash
on balance
PROCESSING
Lead–Free Solderable:
No, Lead Wave Only
ROW
OPTION
–S
STACKER
HEIGHT
–“XXX”
= Single
Row
= Stacker
Height
(in inches)
(5.08 mm)
.200"
minimum
–D
= Double
Row
Example:
–250
= (6.35 mm)
.250"
–T
= Triple Row
–Q
= Double
Row
.200"
(5.08 mm)
row
space
(2.54) .100 x No. of Positions
(2.54)
.100
Example:
–250
= (6.35 mm)
.250"
–“XXX”
—S
= Polarized
(Specify
omitted
pin position)
(5.08)
.200
—D
(7.52)
.296
—T or —Q*
–Q* same as –T except middle row pins are removed
F-224
= ZW
Tail
Length
(in inches)
(1.40 mm)
.055"
minimum
–LL
–T
This Series is non-standard,
non-returnable.
–“XXX”
= Locking
Lead
(Shortest
dimension
between the
tail and the
post is the
end that will
be crimped.
Available on
tails from
(2.29 mm)
.090" to
(7.87 mm)
.310" only.)
Single row,
01 & 02
positions &
–Q row not
available
= Matte
Tin
Notes:
For added mechanical
stability, Samtec recommends
mechanical board spacers be
used in applications with gold or
selective gold plated connectors.
Contact ipg@samtec.com for
more information.
OTHER
OPTION
(2.54)
.100
LEAD
STYLE
OAL
– 07
(10.92) .430
– 08
(13.46) .530
– 09
(18.54) .730
–10
(21.08) .830
–11
(23.62) .930
–12
(26.16) 1.030
–13
(31.24) 1.230
–14
(36.32) 1.430
–15
(16.00) .630
–16
(11.30) .445
–17
(12.19) .480
–19
(33.78) 1.330
–20
(28.70) 1.130
POST
(0.00).000
MIN
OVERALL
LENGTH
(OAL)
STACKER
HEIGHT
TAIL
(1.40) .055
MIN
(2.54)
.100
samtec.com?DW, samtec.com?EW or samtec.com?ZW
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“EW-05-19-T-D-550”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+13.030151+1.68414
