EW-36-14-G-D-1000
EW-36-14-G-D-1000
    SAMTEC(申泰)
    CONN HDR 72POS 0.1 STACK T/H
EW-36-14-G-D-1000 数据手册
ZW–06–13–L–D–787–118 F-218 (Rev 10OCT17) DW–11–20–T–D–825 HW–14–08–G–S–300–100 (2.54 mm) .100" DW, EW, ZW, HW-TH SERIES FLEXIBLE .025" SQ BOARD STACKERS Mates with: SSW, SSQ, ESW, ESQ, CES, SLW, BSW, BCS, SSM, HLE, PHF TYPE STRIP LEAD STYLE NO. PINS PER ROW PLATING OPTION Cable Mates: IDSS, IDSD, SMSD, SMSS DW SPECIFICATIONS Specify LEAD STYLE from chart = (2.79 mm) .110" Tail For complete specifications see www.samtec.com?DW, www.samtec.com?EW, www.samtec.com?ZW or www.samtec.com?HW-TH Insulator Material: DW, EW, ZW: Black Glass Filled Polyester HW: Natural Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin RoHS Compliant: Yes Lead–Free Solderable: DW, EW, ZW: No, Lead Wave Only HW: Yes POST (0.00).000 MIN (2.79) .110 OVERALL LENGTH EW (OAL) STACKER HEIGHT = (8.38 mm) .330" Tail TAIL (1.40) .055 MIN LEAD STYLE OAL – 07 (10.92) .430 – 08 (13.46) .530 – 09 (18.54) .730 –10 (21.08) .830 –11 (23.62) .930 –12 (26.16) 1.030 –13 (31.24) 1.230 –14 (36.32) 1.430 –15 (16.00) .630 –16 (11.30) .445 –17 (12.19) .480 –19 (33.78) 1.330 –20 (28.70) 1.130 ROW OPTION STACKER HEIGHT OTHER OPTIONS –S –“XXX” –“XXX” Example: –250 = (6.35 mm) .250" Example: –250 = (6.35 mm) .250" = Single Row –D = Double Row –T = Triple Row –Q For complete scope of recognitions see www.samtec.com/quality –LL ZW = Gold flash on contact, Matte Tin on tail = Custom Tail FILE NO. E111594 50 02 TAIL LENGTH Notes: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. This Series is non-standard, non-returnable. HW = High Temp Custom Tail (2.54) .100 x No. of Positions –L 01 (2.54) .100 –S (2.54) .100 –D 100 (5.08) .200 ALSO AVAILABLE • Other platings Contact Samtec. ZW or HW TAIL LENGTH (1.40) .055 MIN –F 01 thru 50 01 99 03 150 (7.52) .296 (5.08) .200 01 –T or –Q* = 10 µ" (0.25 µm) Gold on contact area of longer tail, Matte Tin on tail (2.54) .100 –G = 10 µ" (0.25 µm) Gold on contact area of longer tail, Gold flash on balance –Q* 148 = Same as -T except middle row of pins missing. –T = Matte Tin (2.54) .100 TAIL LENGTH (0.64) .025 SQ TYP Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM = ZW or HW Tail Length (in inches) (1.40 mm) .055" minimum STACKER HEIGHT (5.08) .200 MIN = Double Row .200" (5.08 mm) row space (8.38) .330 RECOGNITIONS (MOQ Required) = Stacker Height (in inches) (5.08 mm) .200" minimum All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. = Locking Lead (Shortest dimension between the tail and the post is the end that will be crimped. Available on tails from (2.29 mm) .090" to (7.87 mm) .310" only.) Single row, 01 & 02 positions & –Q row not available –“XXX” = Polarized Specify omitted pin position
EW-36-14-G-D-1000
1. 物料型号: - 型号包括DW、EW、ZW、HW-TH系列,这些是柔性板对板连接器的型号。
2. 器件简介: - 这些连接器是柔性的.025英寸正方形板对板堆叠器,可与SSW、SSQ、ESW、ESQ、CES、SLW、BSW、BCS、SSM、HLE、PHF电缆配对。
3. 引脚分配: - 文档中提到了不同型号的引脚数量,例如DW、EW、ZW系列的引脚数量和排列方式。
4. 参数特性: - 绝缘材料为黑色玻璃填充聚酯,HW系列为天然液晶聚合物。 - 端子材料为磷青铜。 - 镀层为金或锡,覆盖在50微英寸(1.27微米)镍上。 - 工作温度范围为-55°C至+125°C(金镀层)或-55°C至+105°C(锡镀层)。 - 符合RoHS标准,DW、EW、ZW系列不适用于无铅焊接,HW系列适用。
5. 功能详解: - 提供了不同型号的详细规格,如引脚间距、引脚数、引脚长度等。 - 还提供了关于引脚样式、尾长、堆叠高度、整体长度等的选项。
6. 应用信息: - 这些连接器适用于需要柔性连接的应用,如在需要动态弯曲或移动的电子设备中。
7. 封装信息: - 提供了不同封装选项,如单排、双排、三排引脚,以及锁定(LL)选项。
EW-36-14-G-D-1000 价格&库存
很抱歉,暂时无法提供与“EW-36-14-G-D-1000”相匹配的价格&库存,您可以联系我们找货
