FFTP-13-D-03.85-01-N-R
    SAMTEC(申泰)
    .050 X .050 C/L TWISTED PAIR FEM
FFTP-13-D-03.85-01-N-R 数据手册
TIGER ™ IDC EYE TWISTED PAIR IDC CABLES (1.27 mm) .050" PITCH • FFTP/FMTP SERIES FFTP Mates: FTS, FTSH, EHF, SHF FFTP - FMTP –05, –08, –10, –13, –17, –20, –25 Mates: FLE*, SFMC* - –D ASSEMBLY LENGTH - 01 –03.85 = Double End - N - –N = (97.79 mm) 3.85" –R = Notch Polarization (Standard) –08.77 OPTION = Reverse Connector = (222.76 mm) 8.77" ASSEMBLY LENGTH Insulator Material: PBT Contact: FFTP=BeCu Terminal: FMPT=Phosphor Bronze Plating (FFTP): FFTP=10 µ" (0.25 µm) Au over 50 µ" (1.27 µm) Ni on contact area; Sn over 50 µ" (1.27 µm) Ni FMTP=Sn over 50 µ" (1.27 µm) Ni on balance Wire: 30 AWG 7/38, Tinned, Twisted Pair with PVC insulator Operating Temp Range: -40 °C to +105 °C Lead Size Accepted: (0.41 mm) .016" SQ Insertion Depth (FFTP): FFTP=(2.64 mm) .104" to (3.17 mm) .125" MOQ Required END ASSEMBLY (Standard sizes) SPECIFICATIONS ALSO AVAILABLE - NO. PINS PER ROW –18.00 No. of positions x (1.27) .050 + (4.19) .165 = (457.20 mm) 18.00" (Standard lengths) (3.05) .120 (5.08) .200 –D FMTP Other sizes - NO. PINS PER ROW - –05, –08, –10, –13, –17, –20, –25 (Standard sizes) END ASSEMBLY - –D –R ASSEMBLY LENGTH - 01 –03.85 = Double End –T TRANSFER OPTION Leave blank for –D End Assembly. For –T End Assembly Specify “–N” (Sockethas notch polarization) = (97.79 mm) 3.85" –08.77 = Transfer End - = (222.76 mm) 8.77" –18.00 - OPTION –R = Reverse Connector = (457.20 mm) 18.00" (Standard lengths) ASSEMBLY LENGTH No. of positions x (1.27) .050 + (4.19) .165 *Note: Standard FMTP callout will not mate with FLE, SFMC. Must use gold plated callouts. (See drawing on web.) When mated with a socket, Wire 1 mates with Pin 2; Wire 2 mates wth Pin 1, etc. Note: This Series is non-standard, non-returnable. –R (3.05) .120 (5.08) .200 –D –T samtec.com?FFTP or samtec.com?FMTP Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
物料型号:FFTP/FMTP系列IDC电缆
器件简介:该电缆具有1.27毫米(0.050英寸)的间距,FFTP和FMTP两种类型,分别与FTS、FTSH、EHF、SHF和FLE、SFMC等连接器配对。
引脚分配:文档中提到,当与插座配对时,线1与引脚2配对,线2与引脚1配对,依此类推。
参数特性: - 绝缘材料:PBT - 接触材料:FFTP为铍铜,FMPT为磷青铜 - 镀层:FFTP为10微米(0.25微米)金层覆盖在50微米(1.27微米)镍上,FMTP为锡覆盖在50微米(1.27微米)镍上 - 线材规格:30 AWG 7/38,镀锡,双绞线,带有PVC绝缘体 - 工作温度范围:-40°C至+105°C - 接受的引线尺寸:0.41毫米(0.016英寸)平方
功能详解:文档中未提供详细的功能解释,但提到了该系列是非标准产品,不可退货。
应用信息:文档中未明确提供应用信息,但根据电缆规格,可以推断它适用于需要高密度连接和信号完整性的应用。
封装信息:提供了不同行数和组装长度的选项,包括标准尺寸和长度,以及反转连接器和传输端的选项。
FFTP-13-D-03.85-01-N-R 价格&库存
很抱歉,暂时无法提供与“FFTP-13-D-03.85-01-N-R”相匹配的价格&库存,您可以联系我们找货
