FLAT FLEXIBLE CABLE
(FFC) JUMPER & SOCKET
(0.50 mm) .0197" PITCH • FJH/ZF5S SERIES
FJH
FJH
Mates:
ZF5S
NO. OF
POSITIONS
–10, –15,
–20, –25, –30,
–40, –43, –50
SPECIFICATIONS
Conductor:
Tin Plated Copper
Conductor Resistance:
1000 Ω/km max
Current Rating:
1.8 A per pin
(1 pin powered)
Operating Temp Range:
-55 °C to +80 °C
Voltage Rating:
195 VAC
–D
Length in inches
–R
= (76.2 mm) 3.00"
–06.00
–12.00
= (304.8 mm) 12.00"
LENGTH ± (3.18) .125
–24.00
= (609.6 mm) 24.00"
A
± (1.52)
0.06
(Standard Lengths)
(4.00)
.157
—D STYLE
OTHER SOLUTIONS
For 1.00 mm pitch flat
flexible cable series, visit:
www.samtec.com?FJ
www.samtec.com?ZF1
www.samtec.com?FC1
—R STYLE
ZF5S
SPECIFICATIONS
NO. OF
POSITIONS
–10, –15, –20, –25,
–30, –40, –43, –50
Insulator Material:
Natural LCP
Contact Material:
Phosphor Bronze
Plating:
Sn over 50 µ" (1.27 µm) Ni
Weld Tab:
Phosphor Bronze
-55 °C to +105 °C
Current Rating:
1.8 A per pin
(1 pin powered)
(Standard sizes)
LEAD
STYLE
–01
= Contact Bottom
NO. OF
POSTIONS
A
–10
(5.50) .217
–15
(8.00) .315
–20
(10.50) .413
–25
(13.00) .512
–30
(15.50) .610
–40
(20.50) .807
–43
(22.00) .866
–50
(25.50) 1.00
PLATING
OPTION
–T
= Matte Tin
Notes:
Stiffener color will
be blue or black at
Samtec’s discretion.
Some sizes, styles
and options are
non-standard,
non-returnable.
WT
–WT
= Weld Tab
OPTION
–K
= (3.00 mm)
.118" DIA
Polyimide Film
Pick &
Place Pad
–TR
= Tape &
Reel
(No. of positions -1)
x (0.50) .0197
–FR
= Full Reel
Tape & Reel
(must order
max. quantity
per reel;
contact
Samtec for
quantity breaks)
(4.82)
.190
PROCESSING
No. of positions x
(0.50) .0197 + (5.65) .222
(2.00)
.079
(2.10)
.083
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
F-224 (Rev 20OCT23)
–4
= (4.00 mm)
.157"
–03.00
= Reversed End
Other Platings
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (10-30)
(0.15 mm) .006" max (40-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
STRIP
LENGTH
= (152.4 mm) 6.00"
MOQ Required
Mates:
FJH
LENGTH
= Double End
(Standard sizes)
ALSO AVAILABLE
ZF5S
STYLE
ALSO AVAILABLE
MOQ Required
Vertical
Contact top
Other positions
samtec.com?FJH or samtec.com?ZF5S
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“FJH-15-D-17.00-4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 4+56.15062
- 25+50.74594
- 50+47.15491
- 100+44.91808
- 500+36.17628
- 1000+33.26235
- 2500+27.43449
- 4250+21.69126
