FSI-135-10-L-D-AD
FSI-135-10-L-D-AD
    SAMTEC(申泰)
    1MM SINGLE ELEMENT INTERFACE
FSI-135-10-L-D-AD 数据手册
F-215 FSI–120–06–L–D–AD FSI–150–03–G–D–E–AD FSI–150–03–G–D–AD (1,00 mm) .0394" LOW PROFILE & ELEVATED ONE PIECE Choice of board stacking profiles SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?FSI Insulator Material: Liquid Crystal Polymer Contact Material: BeCu Current Rating: 2.8 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +125°C Plating: Au over 50µ" (1,27 µm) Ni RoHS Compliant: Yes Processing: Short version or optional threaded inserts ALSO AVAILABLE (MOQ Required) • No alignment pin • Top side alignment pin • Bottom side alignment pin • Other platings Contact Samtec. Lead-Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (05-30) (0,15 mm) .006" max (50) Compression Board: Gold Pads required • Threaded insert option RECOGNITIONS 1 FSI For complete scope of recognitions see www.samtec.com/quality BODY HEIGHT PINS PER ROW PLATING OPTION –03 = 3,00 mm 10, 20, 30 & 50 –06 (Insert/Screw Option) –10 (Short Version) = 10,00 mm (No. of positions x (1,00) .03937) + (0,76) .030 (0,89) .035 Note: Applications requiring 40-50 positions without threaded inserts, please contact Samtec Interconnect Processing Group. Note: Some lengths, styles and options are non-standard, non-returnable. B BODY HEIGHT –03 (0,36) .014 (No. of positions x (1,00) .03937) + (14,10) .555 –06 (1,40) .055 Low Profile .100" (2,54 mm) Pitch (No. of positions x (1,00) .03937) + (7,24) .285 –06 & –10 Contact Detail Other Solutions See SEI Series. = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail (Not available with –03 body height) (8,22) .324 (0,64) .025 TYP 02 –L = 6,00 mm 05, 10, 20, 30, 50 01 –G = 10µ" (0,25 µm) Gold (–03 only) Insert Option (10, 20 & 30 pins/row) –10 (72,09) 2.838 A (1,00) .03937 Short Version (0,15) .006 (32,62) 1.284 (1,07) .042 DIA –03–AD Shown (1,40) .055 Double Row Version –03, –06, –10 Insert Option (50 pins/row) See SIB Series. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. A B (3,00) (8,76) .118 .345 (6,00) (9,02) .236 .355 (10,00) (9,02) .394 .355 FSI–150–06–L–D–AD FSI–120–06–L–S–AD FSI–120–03–G–S–AD FSI–130–10–L–D–E FSI SERIES Choice of board stacking profiles Single or double row Optional alignment pins on top and bottom Short version or optional threaded inserts ROW OPTION INSERT OPTION ALIGNMENT OPTION –S Leave blank for Short Version (No screw down inserts or holes) Leave blank for no Alignment Pin = Single Row (Available with 5, 10 & 20 pins with –AD alignment pin) –E –AD = #2-56 x 1/16" screw thread –D = Alignment Pin Top & Bottom –M = Double Row OTHER OPTION –WT = Weld Tab (Available with –S row option & –06 & –10 body height only) –K = Polyimide Film Pick & Place Pad (50 position with threaded insert option only) = 2,00 mm x 0,40 mm screw thread (71,20) 2.803 –P = Plastic Pick & Place Pad (5,08 mm) .200" x (12,45 mm) .490" (50 not available with –E) (Not available with –S row option or –03 body height) Insert Option (50 pins/row) (No. of positions x (1,00) .03937) + (5,00).197 (4,60) .181 –TR = Tape & Reel Packaging (5,30) .209 01 05 (0,36) .014 (1,25) .049 (0,87) .034 (No. of positions x (1,00) .03937) + (8,60) .339 –03, –06 & –10 Contact Detail A (1,60) .063 Short Version (1,40) .055 A –03–AD Shown Single Row Version –03, –06, –10 (No. of positions x (1,00) .03937) + (14,70) .579 (2,25) .089 Insert Option (10, 20 & 30 pins/row) –WT Option (–06 & –10 Body only) WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
FSI-135-10-L-D-AD 价格&库存
很抱歉,暂时无法提供与“FSI-135-10-L-D-AD”相匹配的价格&库存,您可以联系我们找货
FSI-135-10-L-D-AD
  • 1+122.934891+15.95070
  • 10+108.3059010+14.05260
  • 30+107.4504030+13.94160
  • 60+105.1405660+13.64190
  • 105+87.34623105+11.33310
  • 255+82.21324255+10.66710
  • 510+74.17158510+9.62370
  • 1005+67.242051005+8.72460
库存:14
