FTS-110-01-LM-DV-P
FTS-110-01-LM-DV-P
    SAMTEC(申泰)
    排针 SMT
FTS-110-01-LM-DV-P 数据手册
F-218 (Rev 29JAN18) FTS–110–02–F–DV FTS–111–02–L–DV–SA FTS–122–01–F–DV FTS–116–02–L–D (1.27 mm) .050" FTS SERIES MICRO LOW-PROFILE TERMINAL STRIPS SPECIFICATIONS Board Mates: CLP, FLE For complete specifications and recommended PCB layouts see www.samtec.com?FTS Cable Mates: FFSD Mates with socket strips or IDC cable Low-profile (1.27 mm) .050" OPTIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Operating Temp Range: -55 °C to +125 °C Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating: 3.4 A per pin (2 pins powered) RoHS Compliant: Yes Lead–Free Solderable: Yes SMT Lead Coplanarity: .004" (0.10 mm) max –S OPTION –SA OPTION Surface mount or through-hole –P OPTION Shrouded and alignment pin options available Micro pitch .050" x .050" (1.27 mm x 1.27 mm) –TR OPTION Impedance matched for high-speed applications RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality FTS 1 NO. PINS PER ROW LEAD STYLE PLATING OPTION ROW OPTION OTHER OPTION –D (–D & –DV only) FILE NO. E111594 (MOQ Required) = .120" (3.05 mm) Post (Mates with FFSD) 02 thru 50 • Alignment pin Contact Samtec. (except –S & –SA option = 05 thru 46) (5.84) .230 –02 No. of positions x .050 (1.27) 02 50 (1.27) .050 (3.42) .135 49 01 (2.16) .085 50 01 No of positions x .050 (1.27) + .325 (8.25) = –SA No of positions x .050 (1.27) + .200 (5.08) = – S 02 (0.86) .034 = .075" (1.91 mm) Post (Mates with FLE) 46 45 = .065" (1.65 mm) Post (Mates with CLP) (0.41) .016 SQ –DV –S –S = Single Through-hole = End Shroud (05 thru 46 positions. Style -02 & -03 only) (1.27) .050 DIA (1.59) .0625 LEAD STYLE – 01 – 02 – 03 – 04 A (3.05) .120 –SV (3.30) .130 X (5.08) .200 (4.06) .160 –P OPTION (1.65) .065 –TR = Tape & Reel (-DV only) (Required callout for positions 2 thru 4) (1.50) .150 (3.56) .140 A –DV –S OPTION –D Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM –P = Pick & Place Pad (04 positions minimum) (1.91) .075 (1.27) .050 A = Single Vertical SMT (1.40) .055 –SA OPTION (2.29) .090 –S –SA = End Shroud with Alignment Pin (05 thru 46 positions. Style -02 & -03 only) –SV = .150" (3.81 mm) Post (Shrouded options removed for clarity) –L = Double Vertical SMT (3.56) .140 (3.48) .137 01 = Double Through-hole = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –04 (4.70) .185 = Gold flash on post, Matte Tin on tail –03 (1.27) .050 (4.57) .180 Note: Some lengths, styles and options are non-standard, non-returnable. –F –01 ALSO AVAILABLE All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
FTS-110-01-LM-DV-P
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作电压范围为3-24V,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有抗干扰能力强,响应速度快等特点。
6. 应用信息:广泛应用于工业控制、仪器仪表等领域。
7. 封装信息:采用DIP-6封装形式。
FTS-110-01-LM-DV-P 价格&库存
很抱歉,暂时无法提供与“FTS-110-01-LM-DV-P”相匹配的价格&库存,您可以联系我们找货
