FW-08-05-L-D-255-155-P
    SAMTEC(申泰)
    .050'' BOARD SPACERS
FW-08-05-L-D-255-155-P 数据手册
MICRO BOARD STACKER 4 G b p s (1.27 mm) .050" PITCH • FW SERIES FW FW Board Mates: CLP, FLE Cable Mates: FFSD - NO. OF PINS PER ROW - 02 thru 50 Specify LEAD STYLE from chart SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (02-30) (0.15 mm) .006" max (31-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) LEAD STYLE LEAD STYLE STACKER HEIGHT STACKER + POST –03 (5.46) to (8.51) .215 .335 (7.11) to (10.16) .280 .400 –05 (8.64) to (15.49) .340 .610 (10.29) to (17.15) .405 .675 - PLATING OPTION -D- STACKER HEIGHT - POST HEIGHT –F –“XXX” –“XXX” –L Example: –250 = (6.35 mm) .250" (1.65 mm) .065" minimum = Gold flash on post, Matte Tin on tail = Stacker Height (in inches) = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail = Post Height (in inches) Example: –065 = (1.65 mm) .065" –G = 10 µ" (0.25 µm) Gold on post, Gold flash on tail No. of positions x (1.27) .050 SURFACE MOUNT —P —ES POST HEIGHT (1.65) .065 MIN –P –TR STACKER HEIGHT 9.91 mm) .390" (2.51) .099 *Processing conditions will affect mated height. —EP —A (3.42) .135 ALSO AVAILABLE Notes: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. POST HEIGHT (1.65) .065 MIN THROUGH-HOLE (2.51) .099 (20.32) .800 MAX OVERALL LENGTH STACKER HEIGHT (5.08) .200 MIN B This Series is non-standard, non-returnable. = Tape & Reel (Max overall height = Post+Stacker Height+Pad+ Alignment Pin = (17.78) .700") (SMT only) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (SMT only) No. of positions x (1.27) .050 Smaller stack heights (MOQ Required) –EP = End Shroud with Guide Post (–075 post height only. Mate only with CLP.) (5.46 mm) .215" to (15.49 mm) .610" stacker height only 9 pins/row min. = Pick & Place Pad (5 positions min.) (SMT only) CLP LEAD MATED STYLE HEIGHT* 8.13 mm) FW-XX-03-X-X-233-065 .329" FW-XX-03-X-X-303-065 –ES = End Shroud (–075 post height only. Mate only with CLP) (5.46 mm) .215" to (15.49 mm) .610" stacker height only 9 pins/row min. = Alignment Pin (3 positions min.) (5.46 mm) .215" to (15.75 mm) .620" stacker height only (SMT only) FW LEAD STYLE –02 OPTION –A (3.42) .135 MATED HEIGHT - —EP —ES LEAD STYLE TAIL (B) –01 (1.14) .045 –02 (1.91) .075 –04 (2.29) .090 samtec.com?FW-SM or samtec.com?FW-TH Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
1. 物料型号:文档中没有明确列出具体的物料型号,但提到了FW系列,可能指的是FLEX STACK MICRO BOARD STACKER系列。
2. 器件简介:文档描述了一种具有不同引脚排列和高度选项的板对板连接器,适用于表面贴装技术(SMT)和通孔技术(TH)。
3. 引脚分配引脚分配包括每排2至50个引脚,具体引脚数取决于用户选择的型号。
4. 参数特性: - 引脚样式:-03、-05等,代表不同的引脚间距和高度。 - 端子材料:磷青铜。 - 绝缘体材料:黑色液晶聚合物。 - 镀层:锡或金,厚度超过50微英寸(1.27微米)的镍层上镀金或金闪。 - 操作温度范围:-55°C至+125°C。
5. 功能详解:文档提供了连接器的详细规格,包括引脚样式、堆叠高度、端子高度等,并解释了不同选项的含义。
6. 应用信息:建议在应用中使用机械板间隔器以增加机械稳定性,特别是对于镀金或选择性镀金连接器。
7. 封装信息:提供了不同引脚样式和堆叠高度的详细尺寸,以及与CLP(Cage Lock Post)连接器配合时的匹配高度。
FW-08-05-L-D-255-155-P 价格&库存
很抱歉,暂时无法提供与“FW-08-05-L-D-255-155-P”相匹配的价格&库存,您可以联系我们找货
