F-224 SUPPLEMENT
HFWS–06–02–T–S–RA
FWS–06–01–T–S
SW–10–04–T–S–350–150
(5.08 mm) .200"
FWS, HFWS, SW SERIES
POWER TERMINAL STRIP
FWS, HFWS Mates with:
PSS, HPF
SW Mates with:
PSS, HPF
SPECIFICATIONS
For complete specifications
see www.samtec.com?FWS
www.samtec.com?HFWS or
www.samtec.com?SW
Insulator Material:
Glass Filled
Polyester (FWS, SW-TH)
Liquid Crystal
Polymer (HFWS, SW-VS)
Terminal Material:
Phosphor Bronze
Plating:
Sn over 50 µ" (1.27 µm) Ni
Current Rating (FWS/PSS):
11.4 A per pin
(1 pin powered)
Operating Temp Range:
-55 °C to +105 °C
Voltage Rating:
500 VAC mated with PSS
RoHS Compliant:
Yes
PROCESSING
Lead–Free Solderable
(HFWS–VS, SW-VS):
Yes
SMT Lead Coplanarity
(FWS, HFWS):
(0.20 mm) .008" max (02-15)*
(0.25 mm) .010" max (16-20)*
SMT Lead Coplanarity (SW):
(0.25 mm) .010" max*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
TYPE
STRIP
NO.
PINS
LEAD
STYLE
FWS
= Matte Tin
HFWS
= High Temp
Header
C
A
01 thru 20
= Surface
Mount with
Pick & Place Pad
(3 Pos. min.)
(6.98 mm) .275"
min. post height
LEAD
STYLE
–01
–02
–04
(2.54)
.100
–05
No. of Positions X (5.08) .200
NO.
PINS
SW
G
–RA
A
(4.57)
.180
(4.57)
.180
(4.09)
.161
(4.57)
.180
B
–T
= Matte Tin
C
D
E
F
STACK
HEIGHT
S
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–RA
G
= Right-angle
–VS
= Surface Mount
(2 pins/row minimum)
Requires HFWS
POST
HEIGHT
–“XXX”
= Stacker Height (in inches)
(0.13 mm) .005" increments
Example: –250 = (6.35 mm) .250"
–“XXX”
= Post Height
(in inches)
(5.08)
.200
TYP
STACK
HEIGHT
(22.61) .890
MAX WITH
(0.00) .000
POST
(7.62) .300
MIN
Leave blank for Through-hole
–VS
02 thru 20
POST
HEIGHT
(0.00)
.000
MIN
(2.54)
.100
(11.94) —
(8.64)
— (10.72)
.470
.422 .340
(13.21) (2.54) (4.57) (8.08) (12.24) (8.38)
.520 .100 .180 .318 .482 .330
(21.06) (4.95) (3.96) (13.82) —
.829 .195 .156 .544
(3.81) —
.150
PLATING
OPTION
04
F
D
(6.35)
.250
(5.08)
.200
TYP
(1.14)
.045
SQ
= Standard
Stacker
FILE NO. E111594
E
(0.51)
.020
STACK
HEIGHT
(2.54) (20.83) .820
.100
MAX
(5.08) .200
MIN
(1.14)
.045
(2.29)
.090
OTHER
OPTION
–VS–P
Specify LEAD STYLE
from chart below.
B
TYPE
STRIP
TAIL
OPTION
S
–T
= Standard Header
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
PLATING
OPTION
(25.91)
1.02
MAX
TAIL
OPTION
Leave
blank for
Through-hole
–VS
=Surface
Mount
(2 pins/row
minimum)
–VS–P
= Surface
Mount with
Pick &
Place Pad
(3 Pos. min.)
(6.98 mm)
.275" max.
post height
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“FWS-02-02-T-S”相匹配的价格&库存,您可以联系我们找货
