HCSD-10-D-17.00-01-N-G 数据手册
F-224 Web
HCMD–10–S–03.00–01
(2.54 mm) .100"
IDC SOCKET & TERMINAL CABLE
Mates with:
TSW, MTSW, TST, HTST,
EW, ZST, MTLW, TSM,
EJH-02 (HCSD only)
TYPE
STRIP
ROW
OPTION
NO. PINS
PER ROW
S
–05, –08,
–10, –12,
–13, –15,
–17, –20
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?HCSD
or www.samtec.com?HCSS
= Single
D
HCSD, HCSS
Insulator Material:
Black Liquid Crystal Polymer
Flammability Rating:
UL 94V-O
Temperature Range:
-20 °C to +105 °C
(Rainbow Cable)
-40 °C to +105 °C (Gray Cable)
Voltage Rating:
425 VAC/600 VDC
Contact:
Phosphor Bronze
Plating:
10 µ" (0.25 µm) Au on
contact area, 150 µ" (3.81 µm)
Sn on balance over
50 µ" (1.27 µm) Ni.
Lead Size Range:
.024" (0.61 mm) SQ to
.026" (0.66 mm) SQ
Lead Insertion Depth:
.185" (4.70 mm) to
.250" (6.35 mm)
Wire:
28 AWG 7/36 stranded
Tinned Copper
RoHS Compliant:
Yes
SPECIFICATIONS
= Double
(Color coded cable N/A
for 36 pins/row.
See –G option.)
Assembled Length in
INCHES (±1/8")
2 inches minimum
(3.30)
.130
–S = Single End
(5.08)
.200
(7.87)
.310
REF
(0.51)
.020
(0.64)
.025
SQ
TYP
(2.54)
.100
LEAD
STYLE
–01
–02
HCMD, HCMS
Socket or Male Plug on one end
A
Single
(HCMS)
(2.54)
.100
–D = Double End
Double
(HCMD)
A
(3.05) .120
(5.84) .230
HCS
= Socket Strip
No. of Positions x .100 (2.54)
+ .180 (4.57)
Socket or Male Plug on each end
(5.08)
.200
(3.30)
.130
–T = Transfer End
(9.53)
.375
REF
(2.54)
.100
Note:
IDC assemblies are
non-standard, non-returnable.
–“XX.XX”
HCM
+ .180 (4.57)
ASSEMBLED
LENGTH
= Assembled Length
= Male Strip
see www.samtec.com?HCMD
or www.samtec.com?HCMS
Insulator Material:
UL 94V-O
Temperature Range:
-20 °C to +105 °C
(Rainbow Cable)
Voltage Rating:
425 VAC/600 VDC
Terminal:
Phosphor Bronze
Plating:
Sn over 50 µ" (1.27 µm) Ni
Wire:
Tinned Copper
RoHS Compliant:
Yes
END
ASSEMBLY
(0.76)
.030
SQ.
Single TYP.
(HCSS)
(2.54)
.100
Double
(HCSD)
Male Plug on one end with socket on other.
Begin part number with HCM.
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
HCSS–15–S–03.00–01–G
HCSD–10–S–03.00–01–T–G
HCMD, HCMS, HCSD, HCSS SERIES
LEAD
STYLE
PLATING
OPTION
–N = Notch Polarization
–S
–01
= HCSS/HCSD or
(3.05 mm) .120" tail for
HCMS/HCMD
= 10 µ" (0.25 µm) Gold on contact area or tail,
Tin on balance
(Standard on HCSS & HCSD. Leave blank)
–02
–T
01
(3.81) .150
Required for HCSS and HCSD.
(Not available on HCMS or HCMD,
unless Transfer, then only the
socket is polarized.)
–S “XX”
–ST “X”
–P “XX”
(50.80)
2.00
min.
Specify Suffix from table. All
dimensions are ± 1/16" (1.59 mm). Not
available in 28 positions and higher.
02
01
04
03
02
04
–R
= Daisy Chain Single
= Stripped & Tinned
= Position Polarization
02
(1.27)
.050
= Tin
(Standard on HCMS & HCMD. Leave blank)
= (5.84 mm) .230" tail
HCMS/HCMD only
OTHER
OPTIONS
NOTCH
POLARIZATION
= Reversed
“XX” ±
/8" (3.18)
1
Single Row
Connectors
01
Outer Most
(End of
Assembly)
03
(101.60)
4.00 minimum
Single
–ST8
–ST4
–ST2
–ST3
Double
Specify “XX” as position. For
Double the same position will
be polarized on both ends. (Not
available on HCM, unless Transfer,
then only the socket is polarized)
When mating double row connector
with two single row connectors, the
outer most single will be connected
to Conductor #1 and the inside
single to Conductor #2.
6
/8" (3.18)
1
/4" (6.35)
1
/2" (12.70)
3
/8" (9.53)
1
–M
= Middle Reversed
–D “XX”
3
–B “XX”
7
= Daisy Chain, Double
= Breakout
(50.80)
2.00
min.
Specify “XX” as number of
conductors to be broken out.
“XX” ±
/8" (3.18)
1
Double Row
Strips
Requires –SXX, –WXX or –DXX
7
1
–G
“XX”
(101.60)
4.00 minimum
(127.00)
5.00 max.
Breakout starts with Number (50.80)
1 lead indicated by brown
2.00 min.
wire or red stripe. Shown on
top side.
= Gray Cable
Standard cable is color coded. Specify
–G for Gray cable with one red edge.
2
Outer Most
(End of
Assembly)
4
–RW
= Reversed Wiring
#1 wire opposite position #1
5
–O
= Outside Reversed
6
–W “XX”
= Wiring Reversed
Daisy Chain, Single
Same as –S “XX” except outer strip
connected to conductor #2 and inside
strip connected to conductor #1.
6
WWW.SAMTEC.COM
7
HCSD-10-D-17.00-01-N-G 价格&库存
很抱歉,暂时无法提供与“HCSD-10-D-17.00-01-N-G”相匹配的价格&库存,您可以联系我们找货
