HSS-102-TT-1A
HSS-102-TT-1A
    SAMTEC(申泰)
HSS-102-TT-1A 数据手册
F-214 SS–132–G–2 ESD–115–G–05 (2,54 mm) .100" SS, SD, ESD, ESS, HSS SERIES PRECISION MACHINED SOCKET STRIPS Mates with: TS, TD, HTS, BBS, BBD, BBL, BDL, BHS TYPE STRIP NO. PINS PER ROW 1 PLATING OPTION LEAD STYLE OTHER OPTION OPTION SPECIFICATIONS –N For complete specifications see www.samtec.com?SS, www.samtec.com?ESS, www.samtec.com?SD, www.samtec.com?ESD or www.samtec.com?HSS Insulator Material: SS, SD, ESS, ESD= Black G.F. Polyester HSS= Black Liquid Crystal Polymer Contact: BeCu Shell: Brass except Style 5A Phosphor Bronze Plating: Au over 50µ" (1,27 µm) Ni or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C Contact Resistance: 10 mΩ Lead Size Range: (0,38 mm to 0,56 mm) .015" to .022" DIA and most IC leads Insertion Force: (Single contact only) Standard= 9 oz (2,50 N) avg., 16 oz (4,45 N) max Low Insertion Force= 2.5 oz (0,70 N) avg., 5.5 oz (1,53 N) max Withdrawal Force: (Single contact only) Standard= 2.5 oz (0,70 N) avg., 1.5 oz (0,42 N) min Low Insertion Force= 2.0 oz (0,56 N) avg., 0.35 oz (0,10 N) min Insertion Depth: (-05, -1X & -21X, -5A) (3,18 mm) .125" to (3,99 mm) .157" Insertion Depth: (-2, -22, -38) (2,41 mm) .095" to (3,68 mm) .145" RoHS Compliant: Yes Lead-Free Solderable: Wave only RECOGNITIONS –S 01 thru 32 –L = 10µ" (0,25 µm) Gold contact, Tin shell (Styles 2 & 22 only) = SS, ESS Series 01 thru 36 Add –L suffix for locking lead socket in end positions. Requires Style -2 or -22 and .035" ± .003 DIA board hole. = 30µ" (0,76 µm) Gold contact, Tin shell SS = Non Flush Locking Socket –T = HSS, SD & ESD Series HSS = Standard Single = High Temp Single Row Socket Row Socket = (0,76) .030 REF (7,62) .300 (3,43) .135 –G = 30µ" (0,76 µm) Gold contact, 10µ" (0,25 µm) Gold shell ESS ALSO AVAILABLE –TT = Elevated Single Row Socket (MOQ Required) = Tin contact and shell (Styles 1, 2, 4, and 05 except LIF N/A) Styles – 5A & –05 socket heads not countersunk. N/A Style –5A Requires -T Plating Option • Locking lead option on ESS and ESD series Contact Samtec. (2,54) .100 x No. of Positions (2,54) .100 –1A, –1B or –1C –03, –04, –05 For LIF specify –21A, –21B or –21C (SS, HSS, SD) For LIF specify –23 (ESS, ESD) (2,54) .100 TYP (2,54) .100 (1,83) .072 DIA SD ESD = Standard Double Row Socket = Elevated Double Row Socket (4,90) .193 (1,32) .052 DIA (0,76) .030 LEAD STYLE Y Style – 5A not available. Styles –5A & –05 socket heads not countersunk. (0,64) .025 SQ –1A or –21A (9,14) .360 –1B or –21B (12,95) .510 –1C or –21C (6,60) .260 (0,76) .030 B Y A C (0,64) .025 SQ (2,54) .100 x No. of Positions –2, –22*,–5A, or –38* (2,54) .100 (5,08) .200 *For LIF specify –22 or –38 (SS, HSS, SD) (2,54) .100 TYP (1,83) .072 DIA (2,54) .100 For complete scope of recognitions see www.samtec.com/quality (0,76) .030 LIF= Low Insertion Force Note: Some lengths, styles and options are non-standard, non-returnable. (1,32) .052 DIA X X LEAD STYLE DIA Z Y Y Z –2 or –22 (0,51) (3,18) (7,62) .020 .125 .300 05 –38 (0,51) (4,57) (8,89) .020 .180 .350 03 or 23 –5A (0,89) (12,95) (17,86) .035 .510 .703 04 Locking lead available. See OPTION. WWW.SAMTEC.COM LEAD STYLE A B C (17,86) (13,46) (4,39) .703 .530 .173 (11,51) (8,38) (3,12) .453 .330 .123 (14,05) (10,92) (3,12) .553 .430 .123
HSS-102-TT-1A 价格&库存
很抱歉,暂时无法提供与“HSS-102-TT-1A”相匹配的价格&库存,您可以联系我们找货
