F-214
SS–132–G–2
ESD–115–G–05
(2,54 mm) .100"
SS, SD, ESD, ESS, HSS SERIES
PRECISION MACHINED SOCKET STRIPS
Mates with:
TS, TD, HTS, BBS,
BBD, BBL, BDL, BHS
TYPE
STRIP
NO. PINS
PER ROW
1
PLATING
OPTION
LEAD
STYLE
OTHER
OPTION
OPTION
SPECIFICATIONS
–N
For complete specifications
see www.samtec.com?SS,
www.samtec.com?ESS,
www.samtec.com?SD,
www.samtec.com?ESD or
www.samtec.com?HSS
Insulator Material:
SS, SD, ESS, ESD=
Black G.F. Polyester
HSS=
Black Liquid Crystal Polymer
Contact:
BeCu
Shell:
Brass except Style 5A
Phosphor Bronze
Plating:
Au over 50µ" (1,27 µm) Ni or
Sn over 50µ" (1,27 µm) Ni
Operating Temp Range:
-55°C to +125°C
Contact Resistance:
10 mΩ
Lead Size Range:
(0,38 mm to 0,56 mm)
.015" to .022" DIA
and most IC leads
Insertion Force:
(Single contact only)
Standard=
9 oz (2,50 N) avg.,
16 oz (4,45 N) max
Low Insertion Force=
2.5 oz (0,70 N) avg.,
5.5 oz (1,53 N) max
Withdrawal Force:
Standard=
1.5 oz (0,42 N) min
2.0 oz (0,56 N) avg.,
0.35 oz (0,10 N) min
Insertion Depth:
(-05, -1X & -21X, -5A)
(3,18 mm) .125" to
(3,99 mm) .157"
Insertion Depth:
(-2, -22, -38)
(2,41 mm) .095" to
(3,68 mm) .145"
RoHS Compliant:
Yes
Lead-Free Solderable:
Wave only
RECOGNITIONS
–S
01 thru 32
–L
= 10µ" (0,25 µm) Gold contact,
Tin shell
(Styles 2 & 22 only)
= SS, ESS Series
01 thru 36
Add –L suffix for locking
lead socket in end positions.
Requires Style -2 or -22 and
.035" ± .003 DIA board hole.
= 30µ" (0,76 µm) Gold contact,
Tin shell
SS
= Non
Flush
Locking
Socket
–T
= HSS, SD & ESD Series
HSS
= Standard Single = High Temp Single
Row Socket
Row Socket
(0,76)
.030
REF
(7,62)
.300
(3,43)
.135
–G
10µ" (0,25 µm) Gold shell
ESS
ALSO AVAILABLE
–TT
= Elevated Single Row Socket
(MOQ Required)
= Tin contact and shell
(Styles 1, 2, 4, and 05
except LIF N/A)
Styles – 5A & –05 socket
heads not countersunk.
N/A Style –5A
Requires -T Plating Option
• Locking lead option on ESS
and ESD series
Contact Samtec.
(2,54) .100 x No. of Positions
(2,54)
.100
–1A, –1B or –1C
–03, –04, –05
For LIF specify –21A, –21B or –21C
(SS, HSS, SD)
For LIF specify –23
(ESS, ESD)
(2,54)
.100 TYP
(2,54)
.100
(1,83)
.072 DIA
SD
ESD
= Standard Double
Row Socket
= Elevated Double
Row Socket
(4,90)
.193
(1,32)
.052
DIA
(0,76)
.030
LEAD STYLE
Y
Style – 5A not available.
Styles –5A & –05 socket
(0,64)
.025 SQ
–1A or –21A
(9,14)
.360
–1B or –21B
(12,95)
.510
–1C or –21C
(6,60)
.260
(0,76)
.030
B
Y
A
C
(0,64)
.025
SQ
–2, –22*,–5A,
or –38*
(2,54)
.100
(5,08)
.200
*For LIF specify –22 or –38 (SS, HSS, SD)
(2,54)
.100 TYP
(1,83)
.072
DIA
(2,54)
.100
For complete scope
of recognitions see
www.samtec.com/quality
(0,76)
.030
LIF= Low Insertion Force
Note:
Some lengths, styles and options are
non-standard, non-returnable.
(1,32)
.052
DIA
X
X
LEAD STYLE DIA
Z
Y
Y
Z
–2 or –22
(0,51) (3,18) (7,62)
.020 .125 .300
05
–38
(0,51) (4,57) (8,89)
.020 .180 .350
03 or 23
–5A
(0,89) (12,95) (17,86)
.035 .510 .703
04
Locking lead available. See OPTION.
WWW.SAMTEC.COM
LEAD
STYLE
A
B
C
(17,86) (13,46) (4,39)
.703
.530 .173
(11,51) (8,38) (3,12)
.453
.330 .123
(14,05) (10,92) (3,12)
.553
.430 .123
