BCS-125-F-D-HE
BCS-125-F-D-HE
    SAMTEC(申泰)
    BOX CONNECTOR SOCKET STRIP
BCS-125-F-D-HE 数据手册
TIGER CLAW™ PASS-THROUGH SOCKET (2.54 mm) .100" PITCH • BCS SERIES BCS Mates: TSW, MTSW, HTSW, HMTSW, TSS, ZSS, DW, EW, ZW, HW, TSM, MTLW, PHT BCS -1 NO. PINS PER ROW 01 thru 50 SPECIFICATIONS - PLATING OPTION - –F ENTRY OPTION –S = Gold flash on contact, Matte Tin on tail - –TE = Single –D OTHER OPTION –“XXX” = Top Entry = Polarized Position (–BE not available) –DE = Double –L Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Voltage Rating: 495 VAC (-TE/-DE/-PE mated with TSM) 450 VAC (-HE mated with TSW) Operating Temp Range: -55 °C to +125 °C Insertion Depth: (4.34 mm) .171" to (7.24 mm) .285" from top, (5.64 mm) .222" plus board thickness minimum from bottom. –HE is (4.34 mm) .171" to (6.35 mm) .250" - ROW OPTION = Top Entry (For Bottom Entry specify –DE–BE) Cannot be used with plated through-holes = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –PE = Pass-through Entry (For Bottom Entry specify –PE–BE) –HE = Horizontal Entry     PROCESSING Lead–Free Solderable: Yes MATES BCS/TSW  [1RRI3RVLWLRQV CURRENT RATING (PER PIN) BCS/TSM 4.6 A 5.0 A 2 POSITIONS POWERED ALSO AVAILABLE     MOQ Required —TE Other Platings     —DE     —PE              Note: Some lengths, styles and options are non-standard, non-returnable. —HE samtec.com?BCS Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
BCS-125-F-D-HE
1. 物料型号:TIGER CLAW™ PASS-THROUGH SOCKET,型号为BCS系列。 2. 器件简介:该器件是2.54mm间距的通孔插座,适用于多种插入方式和配置。 3. 引脚分配:提供1至50个引脚每排的选项,支持多种引脚配置。 4. 参数特性: - 绝缘体材料:黑色液晶聚合物 - 接触材料:磷青铜 - 镀层:10µ"金接触,尾部镀层为亚光锡 - 电压等级:495 VAC(特定配置下) - 工作温度范围:-55°C至+125°C - 插入深度:从顶部4.34mm至7.24mm,底部5.64mm加上板厚的最小值 5. 功能详解:支持多种插入方式,包括顶部、底部和水平插入。 6. 应用信息:适用于高电流应用,例如BCS/TSW的电流额定值为46A,BCS/TSM为50A。 7. 封装信息:提供了不同长度和样式的选项,但某些选项可能为非标准或不可退换。
BCS-125-F-D-HE 价格&库存
很抱歉,暂时无法提供与“BCS-125-F-D-HE”相匹配的价格&库存,您可以联系我们找货
BCS-125-F-D-HE
  • 8+58.313808+7.57803
