BKS-169-01-F-V
BKS-169-01-F-V
    SAMTEC(申泰)
    SMD,P=1mm
    排母 间距:1mm 立贴
BKS-169-01-F-V 数据手册
F-218 BKS–125–01–L–V BKS–115–01–L–V BKS–155–01–L–V–P BKT–111–01–L–V BKT–127–01–L–V–S–P BKT–133–03–L–V BKT–131–05–L–V–S (1.00 mm) .0394" BKT, BKS SERIES POLARIZED MICRO HEADER & SOCKET SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?BKT or www.samtec.com?BKS Insulator Material: Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 2.8 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Insertion Depth: (1.40 mm) .055" minimum Normal Force: 40 grams (0.39 N) average Max Cycles: 100 with 10 µ" (0.25 µm) Au RoHS Compliant: Yes BKT NO. OF POSITIONS 1 Mates with: BKS 07 thru 69 02 (5.08) .200 (2.54) (5.59) .100 .220 (1.00) .03937 A B –01 (1.93) .076 (2.29) .090 (2.79) .110 (3.78) .149 (4.80) .189 (3.91) .154 (4.27) .168 (4.78) .188 (5.77) .227 (6.78) .267 01 –02 (0.31) .012 SQ TYP –03 (1.65) .065 –04 A –05 (0.50) .0197 x (No. of positions +1) + (0.25) .010 OPTIONS = Shrouded (15 positions minimum) –F = Gold flash on post, Matte Tin on tail –A –L BOARD SPACE = Alignment Pin (Metal or plastic at Samtec discretion) (13 positions minimum) = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail (Mated with BKS) (4.14) .163 (4.50) .177 (5.00) .197 –P (6.35) .250 = Pick & Place Pad (13 positions minimum) (6.00) .236 (7.00) .276 (0.50) .0197 x (No. of positions +1) + (2.44) .096 –TR –S OPTION (0.20) .008 (0.89) .035 DIA V –S (4.17 x 5.71) .164 x .225 (1.19) .047 RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality BODY STYLE (0.50) .020 TYP PLATING OPTION Specify BODY STYLE from chart (Odd lead counts only) PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max BODY STYLE = Tape & Reel Packaging (3.61) .142 B –P OPTION –A OPTION FILE NO. E111594 APPLICATIONS BKT BKS BKT LEAD STYLE –01 –02 –03 –04 –05 MATED HEIGHT MATED HEIGHT* (4.14) .163 (4.50) .177 (5.00) .197 (6.00) .236 (7.00) .276 *Processing conditions will affect mated height. 1 BKS NO. OF POSITIONS 01 Mates with: BKT PLATING OPTION V –A –F 07 thru 69 (Odd lead counts only) (07 positions available with –TR only) = Alignment Pin (Metal or plastic at Samtec discretion) (11 positions minimum) = Pre-plated Gold flash on contact, Matte Tin on tail –P –L 02 (4.11) .162 (2.54) (5.59) .100 .220 OPTIONS = Pick & Place Pad (13 positions minimum) Not always necessary for auto placement. = Pre-plated 10 µ"(0.25 µm) Gold contact, Matte Tin on tail –TR = Tape & Reel Packaging 01 (0.36) .014 (1.00) .03937 (0.50) .020 TYP (0.50) .0197 x No. of positions + (0.81) .032 Note: Some sizes, styles and options are non-standard, non-returnable. (2.12) .084 (5.26 x 6.07) .207 x .239 (1.07) .042 (2.21) .087 (0.89) .035 DIA (0.20) .008 –P OPTION –A OPTION Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
BKS-169-01-F-V 价格&库存
很抱歉,暂时无法提供与“BKS-169-01-F-V”相匹配的价格&库存,您可以联系我们找货
