SMT MICRO
HEADER & SOCKET
(0.80 mm) .0315" PITCH • FTE/CLE SERIES
FTE
FTE
Mates:
CLE
-1
CLE
NO. PINS
PER ROW
05
thru
90
Mates:
FTE, AW
TAIL
OPTION
–DV
= 10 µ"
(0.25 µm)
Gold on
post,
Gold flash
on balance
FLEX SHROUD
OPTIONS
= Dual
Vertical
Style –01 –DV only
(11 pins/row
minimum)
–DH
= End Shroud
–A
–EC
= End Shroud with
Locking Clips
(Manual placement
required)
(3.05)
.120
–K
= (2.50 mm)
.098" DIA
Polyimide
Film Pick &
Place Pad
(–DH only)
–EP
= End Shroud with
Guide Posts
No. of positions x
(0.80) .0315 + Z
OPTION
Z
LEAD
STYLE
A
–ES
(1.57)
.062
–01
(1.90)
.075
–EC
(4.11)
.162
–02
(4.45)
.175
–EP
(5.51)
.217
–03
(3.05)
.120
–P
= Plastic Pick
& Place Pad
(8 positions
minimum)
–DV only
–TR
–P OPTION
A
A
(1.38)
.055
(1.70)
.067
(Shrouded options removed for clarity)
CLE
-1
NO. PINS
PER ROW
(4.57)
.180
–DH OPTION
- 01 -
04 thru 90
PLATING
OPTION
–ES OPTION
DV
–G
OTHER
OPTION
= Alignment
Pin
(5 positions
minimum)
Metal or
plastic at
Samtec
discretion
(–DV only)
–ES
= Dual
Horizontal
(50 positions
maximum)
No. of positions x (0.80) .0315
PROCESSING
Lead-Free Solderable:
Yes
SMT Lead Coplanarity (FTE):
-DV: (0.10 mm) .004" max
-DH: (0.10 mm) .004" max (05-25)
(0.15 mm) .006" max (26-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
SMT Lead Coplanarity (CLE):
(0.10 mm) .004" max (04-65)
(0.15 mm) .006" max (66-90)*
ipg@samtec.com)
PLATING
OPTION
–G
Specify
LEAD
STYLE
from
chart
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Contact Material:
BeCu
Plating:
Au over 50 µ" (1.27 µm) Ni
Current Rating (FTE/CLE):
2.7 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth (CLE):
Top Entry =
(1.73 mm) .068" to (3.18 mm) .125"
with (0.38 mm) .015"
wipe, or pass-through
Bottom Entry =
(3.23 mm) .127" minimum plus
board thickness
Max Cycles (CLE):
100 with 10 µ" (0.25 µm) Au
LEAD
STYLE
= Tape & Reel
–FR
= Full Reel
Tape & Reel
(must order
max. quantity
per reel;
contact
Samtec for
quantity
breaks)
OPTIONS
–A
= 10 µ"
(0.25 µm)
Gold
= Alignment Pin
(4 positions minimum)
Metal or plastic at
Samtec discretion.
No. of positions x
(0.80) .0315 + (0.38) .015
–K
= (3.50 mm) .138" DIA
Polyimide film
Pick & Place Pad
(8 positions minimum)
(3.18)
.125
–P
= Metal Pick & Place Pad
(3.12)
.123
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-224
–TR
(3.30)
.130
= Tape & Reel
(4.83)
.190
–P OPTION
–FR
= Full Reel Tape & Reel
(must order max. quantity
per reel; contact Samtec
for quantity breaks)
samtec.com?FTE or samtec.com?CLE
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“CLE-134-01-G-DV-K”相匹配的价格&库存,您可以联系我们找货
