CLM-118-02-F-D-BE
CLM-118-02-F-D-BE
    SAMTEC(申泰)
    1MM MICRO STRIPS
CLM-118-02-F-D-BE 数据手册
F-215 MLE–120–01–G–DV MLE–150–01–G–DV CLM–126–02–F–D CLM–111–02–L–D (1,00 mm) .0394" CLM, MLE SERIES RUGGED RELIABLE MICRO SOCKETS SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?CLM or www.samtec.com?MLE Insulator Material: Black LCP Contact Material: CLM: Phosphor Bronze MLE: BeCu Plating: CLM: Au or Sn over 50µ" (1,27 µm) Ni MLE: Au over 10µ" (0,25 µm) Ni Current Rating (CLM/FTM): 2.8 A per pin (1 pin powered per row) Current Rating (MLE/FTM): 2.9 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +125°C Contact Resistance: CLM: 15 mΩ Max Cycles: CLM: 100 with 10µ" (0,25 µm) Au Voltage Rating: MLE: 310 VAC Insertion Depth: CLM: Top Entry = (1,40 mm) .055" min., Bottom Entry = (2,41 mm) .095" min. (Add board thickness for correct post OAL) MLE: (1,63 mm) .064" to (3,18 mm) .125" with (0,38 mm) .015" wipe, pass-through, or (2,44 mm) .096" minimum for bottom entry Insertion Force: CLM: 1.5 oz (0,42 N) average MLE: 2.70 oz (0,75 N) average Normal Force: CLM: 40 grams (0,39 N) average Withdrawal Force: CLM: .75 oz (0,21 N) average MLE: 0.50 oz (0,14 N) average RoHS Compliant: Yes Lead-Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (02-25) (0,15 mm) .006" max (26-50) CLM NO. PINS PER ROW 1 PLATING OPTION 02 Mates with: FTM, FTMH, MW D –F –BE = Gold flash on contact, Matte Tin on tail 02 thru 50 = Bottom Entry (Required for bottom entry) –L (1,00) .03937 No. of positions x (1,00) .03937 + (0,318) .0125 100 02 = (3,50 mm) .138" DIA Polyimide film Pick & Place Pad (7 positions minimum) –P (2,41) .095 (2,54) .100 = Pick & Place Pad (7 positions minimum) –P 01 (0,28) .011 (1,00) .03937 –K = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail (5,72) .225 x (3,57) .140 (2,26) .089 04-15 16-50 (1,36) .054 –TR = Tape & Reel Packaging –PA (3,56) .140 (7,11) .280 ALSO AVAILABLE (MOQ Required) • Alignment pin • Other Gold plating options Contact Samtec. Pass-Thru MLE 1 NO. PINS PER ROW 01 PLATING OPTION Mates with: FTM, FTMH, MW No. of positions x (1,00) .03937 + (0,20) .008 (1,00) .03937 (0,30) .012 (0,71) .028 –A 01 Note: Some lengths, styles and options are non-standard, non-returnable. –K –P (6,35) .250 x (3,18) .125 (3,30) .130 = Alignment Pin (3 positions minimum) Metal or plastic at Samtec discretion. = (4,00 mm) .1575" DIA Polyimide film Pick & Place Pad (5 positions minimum) (0,64) .025 DIA (4,32) .170 (3,12) .123 –A 02 (3,07) .121 (1,00) .03937 OPTIONS –G 02 thru 50 100 DV = 10µ" (0,25 µm) Gold RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality = Pick & Place Pad with integral Alignment Pin (3,00) .118 (0,89) .035 DIA (7,00) .275 A PIN/ROW APPLICATION –PA (8,26) .325 by A (3,81) .150 (2,12) .084 OPTIONS = Metal Pick & Place Pad (5 positions minimum) (3,50) .138 –P WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. –TR = Tape & Reel Packaging
CLM-118-02-F-D-BE 价格&库存
很抱歉,暂时无法提供与“CLM-118-02-F-D-BE”相匹配的价格&库存,您可以联系我们找货
