F-219 (Rev 03MAR20)
CLP–115–02–L–D
CLP–107–02–F–D–P
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
CLP–130–02–L–D
CLP–116–02–F–DH
HIGH MATING
CYCLES
(1.27 mm) .050"
CLP SERIES
LOW-PROFILE DUAL WIPE SOCKET
High-reliability
Tiger Claw™
contacts
Mates with:
FTSH, FTS, FW
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?CLP
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating (CLP/FTSH):
3.4 A per pin
(2 pins powered)
Voltage Rating:
280 VAC/395 VDC
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
Top Entry = (1.40 mm) .055"
minimum, Bottom Entry =
(2.41 mm) .095" minimum
plus board thickness
DH Entry = (2.31 mm) .091"
to (2.67 mm) .105"
Normal Force:
60 grams (0.59 N) average
Max Cycles:
100 with 10 µ" (0.25 µm) Au
RoHS Compliant:
Yes
(1.27 mm x 1.27 mm)
.050" x .050"
micro pitch
APPLICATIONS
CLP
Low-profile
(2.21 mm)
.087"
FTSH
HORIZONTAL
Surface
mount
Suitable for pass-through
applications
PASS-THRU
CLP
1
NO. PINS
PER ROW
02
ROW
OPTION
PLATING
OPTION
OTHER OPTION
PROCESSING
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-35)
(0.15 mm) .006" max (36-50)*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
02 thru 50
–D
= Double
Row
–L
= Double
Horizontal
(Requires
FTSH–04
lead style)
= Gold flash on contact,
Matte Tin on tail
For complete scope of
recognitions see
www.samtec.com/quality
= Bottom Entry
(Required for bottom entry applications)
–DH
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
RECOGNITIONS
–BE
–F
–G
–K
= 10 µ" (0.25 µm) Gold
(–D only)
= (4.00 mm) .157" DIA
Polyimide film Pick & Place Pad
(5 positions minimum)
FILE NO. E111594
100
ALSO AVAILABLE
No. of Positions
x (1.27) .050 + (0.43) .017
(4.32)
.170
99
• Single row
• Other platings
(1.27)
.050
01
(0.41)
.016
(3.43)
.135
(2.54)
.100
(1.27)
.050
–P OPTION
(2.29)
.090
–DH
PIN/ROW
–P
(6.35)
.250
x
(3.18)
.125
02
(4.57) (3.05)
.180 .120
(MOQ Required)
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
–A
= Alignment Pin
(Not available with –PA option)
(05, 06, 07, 08, 10, 12, 15, 20,
25, 30, 40 positions only)
(–DH option and other sizes. Contact Samtec.)
A
04-15
(3.56) .140
16-50
(7.11) .280
–D
A
If odd pins/row, alignment pins are on middle position
on centerline of the part. If even pins/row, then
alignment pins are between middle two positions.
–PA
= Pick & Place Pad with Alignment Pin
(–D only)
(Not available with –A option)
–TR
(8.25)
.325
(1.40)
.055
= Pick & Place Pad
(5 positions min. –D only)
(Not always necessary for auto placement.
See Flex Processing.)
(3.07)
.121
(0.89)
.035 DIA
(7.00)
.275
–PA OPTION
= Tape & Reel
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
–FR
= Full Reel Tape & Reel Packaging
(Must order maximum quantities per reel.
Contact Samtec for parts per reel)
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
很抱歉,暂时无法提供与“CLP-104-02-G-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+10.09800
- 10+9.87120
- 30+9.70920
- 国内价格 香港价格
- 1+20.338111+2.64389
- 10+17.2788610+2.24620
- 100+14.68580100+1.90911
- 500+13.10878500+1.70410
- 1000+12.483411000+1.62281
- 5000+11.574705000+1.50468
