CLP-128-02-L-D
CLP-128-02-L-D
    SAMTEC(申泰)
    SMD,P=1.27mm
    排母 间距:1.27mm 2x28P 立贴
CLP-128-02-L-D 数据手册
F-219 (Rev 03MAR20) CLP–115–02–L–D CLP–107–02–F–D–P 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT CLP–130–02–L–D CLP–116–02–F–DH HIGH MATING CYCLES (1.27 mm) .050" CLP SERIES LOW-PROFILE DUAL WIPE SOCKET High-reliability Tiger Claw™ contacts Mates with: FTSH, FTS, FW SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?CLP Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (CLP/FTSH): 3.4 A per pin (2 pins powered) Voltage Rating: 280 VAC/395 VDC Operating Temp Range: -55 °C to +125 °C Insertion Depth: Top Entry = (1.40 mm) .055" minimum, Bottom Entry = (2.41 mm) .095" minimum plus board thickness DH Entry = (2.31 mm) .091" to (2.67 mm) .105" Normal Force: 60 grams (0.59 N) average Max Cycles: 100 with 10 µ" (0.25 µm) Au RoHS Compliant: Yes (1.27 mm x 1.27 mm) .050" x .050" micro pitch APPLICATIONS CLP Low-profile (2.21 mm) .087" FTSH HORIZONTAL Surface mount Suitable for pass-through applications PASS-THRU CLP 1 NO. PINS PER ROW 02 ROW OPTION PLATING OPTION OTHER OPTION PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (02-35) (0.15 mm) .006" max (36-50)* *(.004" stencil solution may be available; contact IPG@samtec.com) 02 thru 50 –D = Double Row –L = Double Horizontal (Requires FTSH–04 lead style) = Gold flash on contact, Matte Tin on tail For complete scope of recognitions see www.samtec.com/quality = Bottom Entry (Required for bottom entry applications) –DH = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail RECOGNITIONS –BE –F –G –K = 10 µ" (0.25 µm) Gold (–D only) = (4.00 mm) .157" DIA Polyimide film Pick & Place Pad (5 positions minimum) FILE NO. E111594 100 ALSO AVAILABLE No. of Positions x (1.27) .050 + (0.43) .017 (4.32) .170 99 • Single row • Other platings (1.27) .050 01 (0.41) .016 (3.43) .135 (2.54) .100 (1.27) .050 –P OPTION (2.29) .090 –DH PIN/ROW –P (6.35) .250 x (3.18) .125 02 (4.57) (3.05) .180 .120 (MOQ Required) Note: Some sizes, styles and options are non-standard, non-returnable. –A = Alignment Pin (Not available with –PA option) (05, 06, 07, 08, 10, 12, 15, 20, 25, 30, 40 positions only) (–DH option and other sizes. Contact Samtec.) A 04-15 (3.56) .140 16-50 (7.11) .280 –D A If odd pins/row, alignment pins are on middle position on centerline of the part. If even pins/row, then alignment pins are between middle two positions. –PA = Pick & Place Pad with Alignment Pin (–D only) (Not available with –A option) –TR (8.25) .325 (1.40) .055 = Pick & Place Pad (5 positions min. –D only) (Not always necessary for auto placement. See Flex Processing.) (3.07) .121 (0.89) .035 DIA (7.00) .275 –PA OPTION = Tape & Reel Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM –FR = Full Reel Tape & Reel Packaging (Must order maximum quantities per reel. Contact Samtec for parts per reel) All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
CLP-128-02-L-D 价格&库存
很抱歉,暂时无法提供与“CLP-128-02-L-D”相匹配的价格&库存,您可以联系我们找货
CLP-128-02-L-D
    • 1+59.84280
    • 10+58.42800
    • 30+57.48840
    库存:1
    SSW-105-01-T-S
      库存:100
