COST-EFFECTIVE &
DUAL WIPE SOCKETS 8
G b p s
(2.00 mm) .0787" PITCH • TLE/CLT SERIES
TLE
Mates:
TMMH, TMM, MTMM,
MMT, TW, LTMM, ZLTMM,
TCMD, TSH
-1
TLE
- 01 -
NO. PINS
PER ROW
02 thru 50
CLT
PROCESSING
–G
–P
= Metal Pick & Place Pad
(4 positions minimum)
–TR
—P Option
—A Option
-1
CLT
NO. PINS
PER ROW
02 thru 50
LEAD
STYLE
–01
= Throughhole
= Surface
Mount
D
–03
All options require
Style –02
–L
= Bottom Entry
(Required for bottom
entry applications)
–G
= Alignment Pin
(3 positions minimum)
Metal or plastic at
Samtec’s discretion
–BE
–A
= 10 µ" (0.25 µm)
Gold on contact,
Gold flash on tail
Other Platings
–K
= (5.00 mm) .197" DIA
Polyimide Film
Pick & Place Pad
(04 thru 50 only)
No. of positions x
(2.00) .0787
–P
(4.00)
.157
= Pick & Place Pad
(Not always necessary
for auto placement.)
(2.121)
.0835
CLT
–TR
= Tape & Reel
(36 positions max)
(2.29)
.090
A
(3.02)
.119
—01 or —03
LEAD STYLE
A
–01
(2.16) .085
–03
(2.95) .116
OTHER
OPTIONS
–F
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
= Throughhole
MOQ Required
-FR
= Gold flash
on contact,
Matte Tin on tail
–02
ALSO AVAILABLE
PLATING
OPTION
= Tape & Reel Packaging
(2-37 positions only)
= Full Reel Tape & Reel
(must order maximum
quantity per reel; contact
Samtec for quantity breaks)
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-26)
(0.15 mm) .006" max (27-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–A
= Alignment Pin
1RRISRVLWLRQV[
TLE
Same as TLE except:
(0.10 mm) .004" max (02-25)
(0.15 mm) .006" max (26-34)*
(0.20 mm) .008" max (35-50)*
ipg@samtec.com)
OPTIONS
–K
TLE
Same as TLE except:
Plating:
Sn or Au over 50 µ" (1.27 µm) Ni
Current Rating (TMMH/CLT):
4.1 A per pin
(2 pins powered)
Insertion Depth:
Top Entry=
(1.40 mm) .055" minimum
Bottom Entry=
(2.57 mm) .101" minimum
(add board thickness for
correct post OAL)
Max Cycles:
100 with 10 µ" (0.25 µm) Au
Polyimide Film Pick & Place Pad
SPECIFICATIONS
CLT
DV
= 10 µ" (0.25 µm)
Gold
Mates:
TMM, TMMH, MTMM,
MMT, TW, TSH
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Current Rating (TLE/TMMH):
3.2 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(2.08 mm) .082" to
(4.37 mm) .172" with
(0.38 mm) .015" wipe,
pass-through, or
(3.35 mm) .132" min
for bottom entry
PLATING
OPTION
(5.16)
.203
–02
—A Option
—P Option
–FR
(must order maximum
quantity per reel;
contact Samtec for
quantity breaks)
(36 positions max)
samtec.com?TLE or samtec.com?CLT
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
CLT-108-02-G-D-K-TR 价格&库存
很抱歉,暂时无法提供与“CLT-108-02-G-D-K-TR”相匹配的价格&库存,您可以联系我们找货
