REVISION AB
CLT-1XX-XX-XX-D
No OF POSITIONS
-02 THRU -50
(PER ROW)
DO NOT
SCALE FROM
THIS PRINT
BODY SPECIFICATION
-D: DOUBLE ROW
LEAD STYLE
-01: THROUGH HOLE
(USE C-114-02-XX)
(SEE NOTE 7)
-03: THROUGH HOLE
(USED C-114-03-XX)
(NO OF POS x .0787 [2.00]) .005 [.13]
(CUT TO POSITION) SEE NOTES 3 & 6)
PLATING SPECIFICATION
(VALUES GIVEN ARE IN MICRO-INCHES)
-G: GOLD, 10 Au / 50 Ni MIN ON CONTACT,
3 Au / 50 Ni MIN ON TAIL.
-S: SELECTIVE, 30 Au / 50 Ni MIN
ON CONTACT, MATTE TIN TAIL.
-F: FLASH SELECTIVE, 3 Au / 50 Ni MIN
-SM: SELECTIVE, 30 Au / 50 Ni MIN
-FM: FLASH SELECTIVE, 3 Au / 50 Ni MIN
-L: LIGHT SELECTIVE, 10 Au / 50 Ni MIN
-LM: LIGHT SELECTIVE, 10 Au / 50 Ni MIN
(NO OF POS x .07874 [2.000]) -.07874 [2.000] REF
.024 0.61
SQ REF
"A"
02
CL
'C'
"A"
SEE NOTE 6
.07874 2.000
REF
.1575 4.001
REF
01
'B'
CL
.0835 2.121 REF
C "A"
2 MAX SWAY
(EITHER DIRECTION)
.002 [.051] MIN
.119 3.02 REF
.0200 0.508 X .0050[0.127] REF
SECTION "A"-"A"
SCALE 4 : 1
DETAIL 'B'
SCALE 8 : 1
.0130±.0015 0.330±0.038
C
CL
C-114-XX-XX
CLT-XX-D
DETAIL 'C'
SCALE 16 : 1
LEAD STYLE -01
CLT-111-XX-XX-D SHOWN
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. MINIMUM PUSHOUT FORCE: .5 LB.
3. PARTS TO BE SYMMETRICAL ABOUT CL .
4. WILL LOSE A POSITION FOR EVERY CUT MADE ON A SOCKET STRIP.
5. PACKAGE POSITIONS -04 THRU -50 IN TUBES,
LAYER PACKAGE POSITION -02 THRU -03.
6. ENDWALL AFTER CUTTING: .0215 MIN.
7. C-114-22-XX CAN BE USED FOR C-114-02-XX. C-114-22-XX IS FOR
AUTOMATED ASSEMBLY PROCESSES ONLY.
8. VOID CORES TO BE USED AS NEEDED TO CONTROL WARP,
LOCATION TO BE AT VENDOR DISCRETION
PT-1-24-01-62
TP-12
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [0.3]
10
.XXX: .005 [0.13]
.XXXX: .0020 [0.051]
MATERIAL:
PROPRIETARY NOTE
DO NOT SCALE DRAWING
F:\DWG\MISC\MKTG\CLT-1XX-XX-XX-D-MKT.SLDDRW
SHEET SCALE: 4:1
PT-1-24-01-37
TP-24
PACKAGING VIEW
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
INSULATOR: LCP, UL 94 VO, COLOR: BLACK
CONTACT: PHOS BRONZE
LEAD STYLE -03
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
DWG. NO.
2MM LOW PROFILE SOCKET STRIP
CLT-1XX-XX-XX-D
BY: PURVIS
11-02-95
SHEET 1 OF 1
很抱歉,暂时无法提供与“CLT-150-03-G-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+122.248485+15.88651
