ESQ-116-33-T-D
ESQ-116-33-T-D
    SAMTEC(申泰)
    ELEVATED SOCKET STRIPS
ESQ-116-33-T-D 数据手册
ESQ–132–14–G–D F-219 ESQ–110–44–T–D ESW–115–12–G–S (2.54 mm) .100" ESW, ESQ SERIES ELEVATED SOCKET Mates with: TSW, MTSW, EW, MTLW, TSS, ZSS, TSM, DW, ZW, HW, TSSH, HTSS TYPE STRIP 1 NO. PINS PER ROW LEAD STYLE PLATING OPTION ESW SPECIFICATIONS For complete specifications see www.samtec.com?ESW or www.samtec.com?ESQ = Solder Tail = Square Tail = Single Row –G = Double Row –T = Triple Row (ESQ only) –T 01 thru 36 = Matte Tin (N/A w/LIF contact) 01 36 (2.54) .100 72 02 03 (5.08) .200 (2.54) .100 –T LOW STANDARD INSERTION FORCE INSERTION FORCE 01 (2.54) .100 108 (ESQ only) Specify LEAD STYLE from chart below. (4.95) .195 (2.54) .100 71 FILE NO. E111594 Two leads per strip crimped. N/A with single row 1 or 2 positions. (2.41) .095 –S For complete scope of recognitions see www.samtec.com/quality –LL = Locking Lead –“XXX” = Polarized (2.54) .100 X No. of Positions + (0.51) .020 –D OTHER OPTION –D = 20 µ" (0.51 µm) Gold contact, Gold Flash on Balance RECOGNITIONS (7.49) .295 106 01 – 12 – 37 – 13 – 38 – 23 – 48 – 33 – 58 – 14 – 39 – 24 – 49 – 34 – 59 – 44 – 69 ALSO AVAILABLE (MOQ Required) • Other platings (2.54) .100 TYP ESW (0.41) x (0.79) .016 .031 ESQ (0.64) .025 SQ A (2.29) .090 (7.36) .290 (4.83) .190 (2.29) .090 (12.19) .480 (9.65) .380 (7.11) .280 (4.57) .180 B (11.05) .435 (13.59) .535 (16.13) .635 (11.05) .435 (13.59) .535 (16.13) .635 (18.67) .735 B A APPLICATIONS Note: Some lengths, styles and options are non-standard, non-returnable. –S –L = 10 µ" (0.25 µm) Gold contact, Matte Tin on tail ESQ Insulator Material: Black Glass Filled Polyester Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (ESW/TSW): 5.2 A per pin (2 pins powered) Current Rating (ESQ/TSW): 5.7 A per pin (2 pins powered) Voltage Rating: 550 VAC mated with TSW or ESQ Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Insertion Depth: (3.68 mm) .145" to (6.35 mm) .250" Normal Force: Standard = 125 grams (4.4 N) Max Cycles: 100 with 10 µ" (0.25 µm) Au RoHS Compliant: Yes Lead-Free Solderable: Wave only ROW OPTION Self g Nestkinets Soc (ESQ Series) PC/104™ J1/P1 “Stackthrough” Connectors Standard Insertion Force ESQ-132-14-G-D Low Insertion Force ESQ-132-39-G-D PC/104™ J1 “Non-Stackthrough” Connectors Standard Insertion Force ESQ-132-12-G-D Low Insertion Force ESQ-132-37-G-D PC/104™ J2/P2 “Stackthrough” Connectors Standard Insertion Force ESQ-120-14-G-D Low Insertion Force ESQ-120-39-G-D PC/104 is a trademark of the PC/104 Consortium. Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
ESQ-116-33-T-D 价格&库存
很抱歉,暂时无法提供与“ESQ-116-33-T-D”相匹配的价格&库存,您可以联系我们找货
ESQ-116-33-T-D
  • 13+51.15583
  • 26+44.67565
  • 52+40.62758
库存:56
