ESW-107-23-S-D-11
ESW-107-23-S-D-11
    SAMTEC(申泰)
    排母
ESW-107-23-S-D-11 数据手册
ELEVATED SOCKETS (2.54 mm) .100" PITCH • ESW/ESQ SERIES ESW/ESQ Mates: TSW, MTSW, EW, MTLW, TSS, ZSS, TSM, DW, ZW, HW, TSSH, HTSS SPECIFICATIONS Insulator Material: Black Glass Filled Polyester Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (ESW/TSW): 5.2 A per pin (2 pins powered) Current Rating (ESQ/TSW): 5.7 A per pin (2 pins powered) Voltage Rating: 515 VAC mated with TSW or ESQ Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Insertion Depth: (3.68 mm) .145" to (6.35 mm) .250" Max Cycles: 100 with 10 µ" (0.25 µm) Au SERIES ESW = Solder Tail - NO. PINS PER ROW LEAD STYLE 01 thru 36 Specify LEAD STYLE from chart ESQ = Square Tail - - PLATING OPTION ROW OPTION –L –S = 10 µ" (0.25 µm) Gold contact, Matte Tin on tail = Single Row –D = Double Row –G –T = 20 µ" (0.51 µm) Gold contact, Gold Flash on Balance STANDARD LOW INSERTION INSERTION FORCE FORCE = Triple Row (ESQ only) - OTHER OPTION –LL = Locking Lead (Two leads per strip crimped. Not available with single row 1 or 2 positions) “XXX” = Polarized –T LEAD STYLE PROCESSING Lead-Free Solderable: No, Lead Wave only -1 A B – 12 – 37 (2.29) .090 – 13 – 38 (7.36) .290 = Matte Tin (Not available with LIF contact) (11.05) .435 – 23 – 48 (4.83) .190 (13.59) .535 – 33 – 58 (2.29) .090 (16.13) .635 (12.19) .480 (11.05) .435 – 14 – 39 – 24 – 49 (9.65) .380 (13.59) .535 – 34 – 59 (7.11) .280 (16.13) .635 – 44 – 69 (4.57) .180 (18.67) .735 (2.54) .100 X No. of Positions + (0.51) .020 —S (2.41) .095 —D (4.95) .195 —T (ESQ only) (7.49) .295 APPLICATIONS (ESQ SERIES) PC/104 J1/P1 “Stackthrough” Connectors Standard Insertion Force ESQ-132-14-G-D Low Insertion Force ESQ-132-39-G-D PC/104™ J1 “Non-Stackthrough” Connectors Standard Insertion Force ESQ-132-12-G-D Low Insertion Force ESQ-132-37-G-D PC/104™ J2/P2 “Stackthrough” Connectors Standard Insertion Force ESQ-120-14-G-D Low Insertion Force ESQ-120-39-G-D ™ B ALSO AVAILABLE MOQ Required PC/104 is a trademark of the PC/104 Consortium. Other Platings A Note: Some lengths, styles and options are non-standard, non-returnable. (2.54) .100 TYP ESW (0.41) x (0.79) .016 .031 ESQ (0.64) .025 SQ samtec.com?ESW or samtec.com?ESQ Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
ESW-107-23-S-D-11
物料型号:ESW/ESQ 系列,包括不同引脚数量和配置的型号,如ESQ-132-14-G-D、ESQ-132-39-G-D、ESQ-132-12-G-D、ESQ-132-37-G-D、ESQ-120-14-G-D 和 ESQ-120-39-G-D。
器件简介:这些是2.54mm间距的插座,适用于嵌入式系统和PC/104模块化系统。
引脚分配:文档提供了不同配置的引脚分配,例如标准插入力和低插入力选项。
参数特性:绝缘材料为黑色玻璃填充聚酯,接触材料为磷青铜,镀层为金或锡覆盖50微米(1.27微米)镍。电流额定值为每针5.2A(ESW/TSW)或5.7A(ESQ/TSW),电压额定值为515V AC,与TSW或ESQ配合使用。
功能详解:文档描述了不同的引脚样式、插入力选项和锁定选项。
应用信息:适用于嵌入式系统、PC/104堆叠式连接器和模块化系统。
封装信息:提供了不同引脚配置和行数的详细尺寸和规格。
ESW-107-23-S-D-11 价格&库存
很抱歉,暂时无法提供与“ESW-107-23-S-D-11”相匹配的价格&库存,您可以联系我们找货
