ET60S-D03-3-08-D02-L-V1-S 数据手册
F-217 (Rev 13FEB17)
ET60S–A04–5–03–D04–L–VP–S
(5.50 mm) .217"(PWR) (2.54 mm) .100"(SIG)
ET60S–D04–3–08–A04–L–V1–S
ET60S SERIES
VERTICAL POWER/SIGNAL SOCKET
Mates with:
ET60T
POWER
OPTION (RIGHT)
ET60S
SIGNAL POSITIONS
PER ROW
ROWS
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?ET60S
–0
Insulator Material:
Black LCP
Terminal Material:
Signal: Copper Alloy
Power: Copper Alloy
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
Power: 60 A max per blade
(2 pins powered @ 95 °C;
30 °C temperature rise)
Signal: 2.8 A max
(6 pins powered @ 95 °C;
Operating Temp Range:
-40 °C to +105 °C
RoHS Compliant:
Yes
–02, –04, –06,
–08, –10, –12
= No Signal
–AXX*
= AC Power Positions
(–02, –03, –04, –05, –06 positions only)
(3 Row only)
–3
–01, –02, –03, –04,
–05, –06, –07, –08
= 3 Rows
–DXX
–5*
= DC Power Positions
( –02, –03, –04, –05, –06, –07,
–08, –09, –10 positions only)
(5 Row only)
= 5 Rows
–00
–SXX*
= No Signal
= Split Power
–000
Note:
–AXX*, –SXX*, –5* & –T* are Preliminary
= No Power
A
(2.54)
.100
(7.50)
.295
PROCESSING
B
C
(5.50)
.217
A
POWER
POWER
POSITIONS POSITIONS
AC
(LEFT)
(RIGHT)
POWER
Lead-Free Solderable:
Yes
(18.00)
.709
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
A + C + B + (33.98) 1.338
FILE NO. E111594
(2.60)
.102
(4.81)
.189
(3.00)
.118
(5.17)
.204
(0.64)
.025
SQ
ET60S–D03–3–08–A04–X–V1–S
ALSO AVAILABLE
(MOQ Required)
A
(2.00) .079
–02
–02
–03
–03
–04
–04
–05
–05
–06
–06
**(7.50)
.295
**(15.00)
.591
**(22.50)
.886
**(30.00)
1.181
**(37.50)
1.476
–07
–07
N/A
–08
–08
N/A
–09
–09
N/A
–10
–10
N/A
D
C
TAIL
–VP
–V1
3 ROWS
E
F
EXTreme Ten60Power™
is a trademark of Molex
Incorporated and is dual
sourced by Molex®
(2.83)
.111
(2.00)
.079
(5.28)
.208
(8.82)
.347
ET60S–A04–5–03–D04–X–VP–S
E
(5.32)
.209
(1.65) .065
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
5 ROWS
E
F
(2.83) (2.83) (2.50)
(3.28) .111 .111 .098
.129 (2.60)
N/A
.102
A + C + D + (34.21) 1.347
(9.18)
.361
(5.50)
.217
(11.00)
.433
(16.50)
.650
**(22.50)
.886
**(27.50)
1.083
**(33.00)
1.299
**(38.50)
1.516
**(44.00)
1.732
(49.50)
1.949
**Not Released
• Increased creepage
and clearance with the
removal of contacts
Contact Samtec.
Notes:
Some lengths, styles and
options are non-standard,
non-returnable.
C
DC
POWER
F
(0.93)
.037
(6.60) .260
ET60S–D04-5–03–A04–S–R1–S
F-217 (Rev 13FEB17)
ET60S–D04-3–08–A04–L–R1–S
ET60S SERIES
RIGHT-ANGLE POWER/SIGNAL SOCKET
POWER
OPTION (LEFT)
PLATING
–L
–AXX*
–DXX
(–02, –03, –04, –05, –06, –07,
–08, –09, –10 postions only)
GUIDE
POST
TAIL
–S
–VP
= 10 µ" (0.25 µm) Gold on contact,
Matte Tin on tail
(Not available for 5 rows)
= Vertical Press-fit
= Side
Guide Post
–S
= Vertical through-hole
(Use with (1.60 mm) .062" thick card)
(3 Row only)
–V1
= 30 µ" (0.76 µm) Gold on contact,
Matte Tin on tail
–T*
= Top
Guide Post
–R1
–SXX*
= Right-angle through-hole
= Split Power
–000
D
A
= No Power
(2.00)
.079
C
Note:
A + D + C + (27.21) 1.071
(0.64) .025 SQ
F
A + D + C + (34.21) 1.347
SIGNAL
POSITIONS
PER ROW
(3 Row)
B
*–02
(2.54)
.100
*–04
(7.62)
.300
*–06 (12.70)
.500
–08 (17.78)
.700
*–10 (22.86)
.900
*–12 (27.94)
1.100
*Not Tooled
**Not Released
SIGNAL
POSITIONS
PER ROW
(5 Row)
**–01
N/A
**–02
(2.00)
.079
(4.00)
.157
(6.00)
.236
(8.00)
.315
(10.00)
.394
(12.00)
.472
(14.00)
.551
**–03
*–04
**–05
**–06
**–07
**–08
(3.33)
.131
DIA
D
(4.94) .194
(5.50)
.217
(5.50)
.217
(5.27)
.207
E
ET60S–D04–5–03–A04–X–R1–S
(7.50)
.295
A
(10.00)
.394
A + B + C + (26.98) 1.062
(0.64) .025 SQ
A + B + C + (33.98) 1.338
TAIL
R1
E
F
(2.84)
.112
(2.50)
.098
(5.00)
.197
(5.60)
.220
(5.50)
.217 (7.50)
.295
(3.00)
.118
(4.81)
.189
(5.17)
.204
(5.50)
.217
(5.50)
.217
(3.00) .118
ET60S–D03–3–08–A03–X–R1–S
WWW.SAMTEC.COM
(4.48)
.176
(14.48)
.570
C
(5.50)
.217
B
(2.54) .100
(25.22)
.993
