FTSH-112-01-L-DH-TR
FTSH-112-01-L-DH-TR
    SAMTEC(申泰)
    .050'' X .050 TERMINAL STRIP
FTSH-112-01-L-DH-TR 数据手册
F-215 (Rev 17SEP15) FTSH–110–01–L–DV FTSH–120–01–F–DV FTSH–125–01–L–DV–EJ (1.27 mm) .050" SMT MICRO HEADER SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?FTSH Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50µ" (1.27 µm) Ni Current Rating (FTSH/CLP): 3.3 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +125°C RoHS Compliant: Yes APPLICATIONS Mates with: FFSD, FFTP, CLP, FLE OTHER SOLUTIONS CLP FTSH OPTIONS –ES OPTION –P OPTION HORIZONTAL (1.27 mm) .050" –EC OPTION –EP OPTION Ultra-low profile option available. End Shrouds available. Call for FTS Series specifications. Processing: Lead-Free Solderable: Yes SMT Lead Coplanarity: –MT & –DV Tail Option: (0.10 mm) .004" max (02-25) –MT & –DH Tail Option: (0.15 mm) .006" max (26-50) RECOGNITIONS –EJ OPTION –EL OPTION LEAD STYLE NO. PINS PER ROW 1 FTSH –TR OPTION For complete scope of recognitions see www.samtec.com/quality –01 = (3.05 mm) .120" Post (Mates with FFSD, CLP–DH) FILE NO: 090871_0_000 02 thru 50 –02 ALSO AVAILABLE • Molded Pick & Place pads • Latches • Other platings Contact Samtec. A No. of positions x (1.27) .050 + Z (MOQ Required) 100 02 (4.78) .188 (1.27) .050 01 –EX OPTION SHOWN (0.81) .032 (0.51) .020 (2.29) .090 99 –DH (Styles –01, –02, –04 only) No. of positions x (1.27) .050 + Z (5.64) .222 OPTION Z – ES (2.57) .101 (15.77) .621 (3.33) .131 (5.87) .231 (6.53) .257 –EJ –EJ OPTION SHOWN –EC No. of positions x (1.27) .050 02 100 –EP (3.43) .135 (1.27) .050 01 = (1.91 mm) .075" Post (Mates with FLE) (5.33) .210 –EL (0.40) .016 SQ 99 A –03 = (1.65 mm) .065" Post (Mates with CLP–D) –04 = (3.81 mm) .150" Post –05 = (4.32 mm) .170" Post (Mates with CLP–BE) LEAD STYLE – 01 (5.08) .200 A Note: Some sizes, styles and options are non-standard, non-returnable. Note: See SFM/TFM for positive alignment feature. (1.27) .050 (5.84) .230 –DV – 03 – 04 (2.51) .099 (2.92) .115 – 02 – 05 (1.27) (0.81) (2.29) .050 .032 .090 –MT (Styles –01, –02 & –04 only) WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. A (3.05) .120 (1.91) .075 (1.65) .065 (3.81) .150 (4.32) .170 FTSH–112–02–L–DH FTSH–130–02–L–DV–EP FTSH–116–02–L–DV FTSH–110–01–F–DV FTSH–116–03–L–DV–EP–P FTSH SERIES Optional guide post (2.92 mm) .115" Surface mount (1.27 mm) .050" micro pitch PLATING OPTION –F TAIL OPTION OPTION –DV Leave Blank for -DH & -MT = Gold flash on post, Matte Tin on tail = Double Vertical –L = Double Horizontal (Styles –01, –02 & –04 only) = 10µ" (0.25 µm) Gold on post, Matte Tin on tail –MT –ES –EL = End Shroud = End Shroud with Board Lock (Boards are positively locked and cannot be unmated) –EC = End Shroud with Locking Clip (Manual placement required) –EP = End Shroud with Guide Post (1.91) .075 DIA (3.05) .120 –EJ –C (0.89) .035 DIA –P –A (1.17) .046 (3.05) .120 (2.16) .085 (5.08) .200 (11.18) .440 (3.20) .126 (3.30) .130 x (5.08) .200 –EJ –K (0.86) .034 = Pick & Place Pad (–DV 4 positions min.) (–DH & –MT not available) –TR (4.10) .160 (2.29) .090 –EL –A = (5.00 mm) .197" DIA Polyimide film Pick & Place Pad (–DH only) –EP –ES = Keying Shroud (For mating with FFSD Style –01 only and 05, 08, 10, 13, 17, 20 & 25 pins/row only. 13, 17, 20 & 25 pins/row only with –EJ option) (–DV only) = Alignment Pin (–DV 3 positions min.) (–DH 5 positions min.) (Metal or plastic at Samtec discretion) = Ejector Shroud (Style –01 only) –DH & –MT not available 10 pins/row minimum 25 pins/row maximum (4.83) .190 (4.83) .190 –K (Style –02 & –03 only, –DH & –MT not available) 9 pins/row minimum (Other positions available. Call Samtec.) = Polarized Position (Specify position of omitted pin) (Not available with -EX options) = Mixed Technology (Styles –01, –02 & –04 only) (1.22) .048 OTHER OPTIONS FLEX SHROUD OPTIONS –“XXX” –DH Optional end shrouds and ejector shrouds –P – EC WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. = Tape & Reel Packaging (Flex Shroud options not available except –ES & –EJ)
FTSH-112-01-L-DH-TR
物料型号: - FTSH-110-01-L-DV - FTSH-120-01-F-DV - FTSH-125-01-L-DV-EJ
器件简介: - 这些连接器是延长寿命产品,符合RoHS标准,绝缘体材料为黑色液晶聚合物,端子材料为磷青铜,镀层为锡或金。
引脚分配: - 提供了不同引脚数量和间距的选项,例如02至50引脚,间距为1.27mm。
参数特性: - 每个引脚的电流额定值为3.3A,操作温度范围为-55°C至+125°C。
功能详解: - 连接器与FFSD、FFTP、CLP、FLE等产品兼容,提供多种选项,如水平和垂直尾选项、端罩、极化遗漏引脚位置等。
应用信息: - 适用于表面贴装,可选的导引柱和端罩/弹射罩。
封装信息: - 提供了详细的尺寸和引脚样式信息,以及可选的尾选项和端罩选项。
FTSH-112-01-L-DH-TR 价格&库存
很抱歉,暂时无法提供与“FTSH-112-01-L-DH-TR”相匹配的价格&库存,您可以联系我们找货
