FW-13-05-G-D-378-080-A
    SAMTEC(申泰)
    SAMTEC - FW-13-05-G-D-378-080-A - Pin Header, 1.27 mm, 2 Rows, 26 Contacts, Surface Mount, FW
FW-13-05-G-D-378-080-A 数据手册
F-219 (Rev 05JUL19) FW–20–05–F–D–610–065 FW–12–05–G–D–530–101 (1.27 mm) .050" FW-SM SERIES SMT MICRO BOARD STACKER SPECIFICATIONS Board Mates: CLP, FLE For complete specifications and recommended PCB layouts see www.samtec.com?FW-SM Cable Mates: FFSD Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C RoHS Compliant: Yes Low-profile or skyscraper styles APPLICATIONS Variable board spacing FW MATED HEIGHT CLP PROCESSING LEAD STYLE FW MATED CLP HEIGHT* (8.13) FW-XX-03-X-X-233-065 .320 –02 (9.91) FW-XX-03-X-X-303-065 .390 *Processing conditions will affect mated height. Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (02-30) (0.15 mm) .006" max (31-50)* *(.004" stencil solution may be available; contact IPG@samtec.com) (1.27 mm x 1.27 mm) .050" x .050" micro pitch Surface mount RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality NO. PINS PER ROW FW Specify LEAD STYLE from chart FILE NO. E111594 02 thru 50 ALSO AVAILABLE LEAD STYLE (MOQ Required) PLATING OPTION D –F –L –03 –05 = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail STACKER + POST (5.46) (8.51) (7.11) (10.16) .215 to .335 .280 to .400 (8.64) (15.49) (10.29) (17.15) to .340 .610 .405 to .675 02 No. of positions x (1.27) .050 = Stacker Height (in inches) Example: –250 = (6.35 mm) .250" = 10 µ" (0.25 µm) Gold on post, Gold flash on tail (1.27) .050 99 POST HEIGHT (1.65) .065 MIN This Series is non-standard, non-returnable. Example: –065 = (1.65 mm) .065" (3.45) .136 x (5.08) .200 (4.27) .168 (4.06) .160 (0.76) .030 (1.91) .075 DIA (3.05) .120 (2.92) .115 –EP (0.89) .035 DIA (0.86) .034 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. –ES = End Shroud (–075 post height only. Mate only with CLP) (5.46 mm) .215" to (15.49 mm) .610" stacker height only 9 pins/row min. –EP = End Shroud with Guide Post (–075 post height only. Mate only with CLP.) (5.46 mm) .215" to (15.49 mm) .610" stacker height only) 9 pins/row min. = Alignment Pin (3 positions min.) (5.46 mm) .215" to (15.75 mm) .620" stacker height only –P –P –A OPTION –A –ES STACKER HEIGHT (2.51) .099 (1.65 mm) .065" minimum (4.76) .188 (0.41) .016 SQ Notes: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. –“XXX” 100 (1.19) .047 01 POST HEIGHT = Post Height (in inches) –G (3.42) .135 (1.27) .050 –“XXX” = Gold flash on post, Matte Tin on tail • Smaller stack heights LEAD STACKER STYLE HEIGHT STACKER HEIGHT = Pick & Place Pad (5 positions min.) –TR = Tape & Reel (Max overall height = Post+Stacker Height+ Pad+Alignment Pin = .700 (17.78))
FW-13-05-G-D-378-080-A 价格&库存
很抱歉,暂时无法提供与“FW-13-05-G-D-378-080-A”相匹配的价格&库存,您可以联系我们找货
