HSEC8-160-01-L-RA-BL-TR 数据手册
F-217
HSEC8–160–01–L–RA–BL
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
HSEC8–120–01–L–RA
(0.80 mm) .0315"
HSEC8-RA SERIES
RIGHT-ANGLE EDGE RATE CARD SOCKET
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?HSEC8-RA
Insulator Material:
Black Liquid Crystal Polymer
Contact:
BeCu
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
2.6 A per pin
(2 adjacent pins powered)
Operating Temp:
-55 °C to +125 °C
RoHS Compliant:
Yes
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (10-60)
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
FILE NO. E111594
Rugged
Edge Rate®
contacts
designed for
Signal Integrity
Card Mates:
(1.60 mm) .062" thick card,
HSC8
Cable Mates:
ECDP
Optional
Board
Locks
HIGH-SPEED CHANNEL PERFORMANCE
HSEC8-RA
Rating based on Samtec reference channel.
For full SI performance data visit Samtec.com
or contact SIG@samtec.com
30
Accepts (1.60 mm) .062"
PCB thicknesses
G b p s
• Board lock option
HSEC8
POSITIONS
PER ROW
1
CARD
THICKNESS
–01
FILE NO: 090871_0_000
= (1.60 mm) .062"
thick card
09, 10, 13, 20, 25,
30, 40, 49, 50, 60
ALSO AVAILABLE
(MOQ Required)
PLATING
OPTION
(1.75)
.069
Notes:
While optimized for
50 W applications, this
connector with alternative
signal/ground patterns may
also perform well in certain
75 W applications. Contact
Samtec for further information.
Some lengths, styles and
options are non-standard,
non-returnable.
(1.32)
.052 DIA
(12.05)
.474
(5.20)
(3.00) .205
.118
10, 20 & 30
POSITIONS
PER ROW
40
(0.50)
.020
(7.00)
.276
A
02
50
60
40-BL
C
50-BL
60-BL
01
–L2
–TR
(0.80) .0315
B
= ECDP Latching
(09, 13, 25,
49 only)
(For use with
ECDP)
= Tape & Reel
Packaging
(10 thru 60
positions only)
01
(1.25)
.049
–S
(1.10)
.043
No. of Positions x (0.80) .0315 + (8.61) .339
02
= Board Locks
(09, 13, 25, 40,
49, 50, 60 only)
= 30 µ" (0.76 µm)
Gold on contact,
Matte Tin on tail
(1.32)
.052
No. of Positions x
(0.80) .0315 + (5.38) .212
–BL
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
• Other platings
Contact Samtec.
(9.30)
.366
OTHER
OPTION
RA
40, 50 & 60
–BL
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
A
B
C
(43.80)
1.724
(51.80)
2.039
(59.80)
2.354
(51.30)
2.020
(59.30)
2.335
(67.30)
2.650
(18.90)
.744
(22.90)
.902
(26.90)
1.059
(18.90)
.744
(22.90)
.902
(26.90)
1.059
(36.60)
1.441
(44.60)
1.756
(52.60)
2.071
(36.60)
1.441
(44.60)
1.756
(52.60)
2.071
HSEC8-160-01-L-RA-BL-TR 价格&库存
很抱歉,暂时无法提供与“HSEC8-160-01-L-RA-BL-TR”相匹配的价格&库存,您可以联系我们找货
