F-224 WEB
SS–132–G–2
ESD–115–TT–05
SS, SD, ESD, ESS, HSS SERIES
(2.54 mm) .100"
PRECISION MACHINED SOCKET STRIPS
Mates with:
TS, TD, HTS, BBS,
BBD, BBL, BDL, BHS
TYPE
STRIP
NO. PINS
PER ROW
1
LEAD
STYLE
PLATING
OPTION
OTHER
OPTION
OPTION
SPECIFICATIONS
For complete specifications
see www.samtec.com?SS,
www.samtec.com?ESS,
www.samtec.com?SD,
www.samtec.com?ESD or
www.samtec.com?HSS
Insulator Material:
SS, SD, ESS, ESD=
Black G.F. Polyester
HSS=
Black Liquid Crystal Polymer
Contact:
BeCu
Shell:
Brass except Style 5A
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni or
Sn over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C
Lead Size Range:
(0.38 mm to 0.56 mm)
.015" to .022" DIA
and most IC leads
RoHS Compliant:
Yes
Lead-Free Solderable:
SS, SD, ESS, ESD:
No, Lead Wave only
HSS: Yes
01 thru 32
=SS, ESS Series
01 thru 36
=HSS, SD & ESD Series
SS
HSS
–T
–TT
(4.90)
.193
(1.32)
.052
DIA
(2.54) .100 x No. of Positions
(2.54)
.100
(2.54)
.100
ESD
= (5.08)
Standard
.200
Row Socket
–03, –04, –05
For LIF specify –23
(ESS, ESD)
(1.83)
.072 DIA
(2.54)
.100
(2.54)
Double
.100 TYP
• Locking lead option on ESS
and ESD series
For LIF specify –21A, –21B or –21C
(SS, HSS, SD)
(2.54)
.100 TYP
SD
(MOQ Required)
–1A, –1B OR –1C
(2.54)
.100
ALSO AVAILABLE
LIF= Low Insertion Force
(2.54)
.100
N/A Style –5A
Requires -T Plating Option
= Tin contact and shell
(Styles 1, 2, 4, and 05
except LIF N/A)
Styles –5A & –05 socket
heads not countersunk.
(0.76)
.030
REF
(7.62)
.300
(3.43)
.135
= 30 µ" (0.76 µm)
Gold contact,
10 µ" (0.25 µm) Gold shell
= Elevated Single Row Socket
–N
= Non
Flush
Locking
Socket
Add –L suffix for locking
lead socket in end positions.
Requires Style -2 or -22 and
.035" ± .003 DIA board hole.
= 30 µ" (0.76 µm) Gold
contact, Tin shell
ESS
FILE NO. E111594
–L
= 10 µ" (0.25 µm) Gold
contact, Tin shell
(Styles 2 & 22 only)
–G
= Standard
= High Temp
Single Row Socket Single Row Socket
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
–S
(0.76)
.030
LEAD STYLE
–1A or –21A
Y
= Elevated Double
(2.54)
Row Socket .100
–1B or –21B
(0.64)
.025 SQ
(2.54)
Style .100
–5A
not available.
TYP
–1C or –21C
Y
(9.14)
.360
(12.95)
.510
(6.60)
.260
(0.76)
.030
B
A
C
(0.64)
.025
SQ
–2, –22*,–5A,
or –38*
*For LIF specify –22 or –38 (SS, HSS, SD)
(2.54)
.100 TYP
(2.54)
.100
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(1.83)
.072
DIA
(2.54)
.100
(5.08)
.200
(0.76)
.030
(1.32)
.052
DIA
Z
Y
X
LEAD
STYLE
–2 or –22
–38
–5A
X
DIA
Y
Z
(0.51) (3.18) (7.62)
.020 .125 .300
(0.51) (4.57) (8.89)
.020 .180 .350
(0.89) (12.95) (17.86)
.035 .510 .703
LEAD
STYLE
–05
–03 or
–23
–04
A
B
C
(17.86) (13.46) (4.39)
.703
.530 .173
(11.51) (8.38) (3.12)
.453
.330 .123
(14.05) (10.92) (3.12)
.553
.430 .123
Locking lead available. See OPTION.
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“HSS-114-S-22”相匹配的价格&库存,您可以联系我们找货
